RPM's 414ci dynoed 540rwhp today
Old 08-05-2006, 01:06 PM
  #61
SuperGook's Avatar
Why don't you take him out Dan and give him some lessons. lol
  #62
SuperGook's Avatar
So when are we all going to meet up tonight?
Old 08-05-2006, 02:00 PM
  #63
silver01z06's Avatar
i know talking to jeremy and dan in the past they dont believe in corrected numbers from the dyno. they say they want to know what the car is making right then. were these numbers corrected or what it was making right then?
Old 08-05-2006, 02:07 PM
  #64
mellowyellow's Avatar
SAE Doug Jeremy has learned the value in it....
Old 08-05-2006, 02:14 PM
  #65
Vcious04's Avatar
Nice Jeremy! When I finally recieve my KB "Big Bore" 2.8, I would love to see what they can do together.
Originally Posted by Forteen3GT
i would like to take a cruise with Germ........... about 5 or 6 of us on a Sat. Night...... just wanna see how bad he pulls me on the hose tuned.
Shoot me a pm if ya'll meetup.
Old 08-05-2006, 02:31 PM
  #66
It seems that might be a possibility after all...
Old 08-05-2006, 02:48 PM
  #67
TINKRD's Avatar
Originally Posted by dan03mach
for now untill I get ahold of your car one weekend and throw a kit on there... You can have 700rwhp with just a touch of the botton..
not unless he wants his car to go boom!!
12.0 compression running 24* timing and a big shot....dont see it staying together that long.
is he running ARP head studs?
Old 08-05-2006, 02:51 PM
  #68
WizeAss's Avatar
you in on this??? I should have my rear end fixed this week... darn rear aint under the car anymore... that is why i chewed a chunk on the passenger side
rear tire....... kept hittin the fender on dips.... for a while I thought it was the TD's.
Germ, what are the specs on the heads you had???
Old 08-05-2006, 02:53 PM
  #69
WizeAss's Avatar
that is why I said Sneaky Pete!!!! maybe a 65 shot to cool the intake charge???
Old 08-05-2006, 02:56 PM
  #70
Your car broke again ?
Old 08-05-2006, 03:08 PM
  #71
9 Sec. Club!!!
dan03mach's Avatar
Yes he is, JP didn't you know Nitrous loves high compression.. He can pull a little bit of timing if needed.. A 200 shot won't hurt anything.. Hell I bet I could put a 200 shot on my stock motor and it would last a little while..
Old 08-05-2006, 03:09 PM
  #72
9 Sec. Club!!!
dan03mach's Avatar
How about next Wednesday? Mellow and I are talking about going to the track...
Old 08-05-2006, 03:11 PM
  #73
TINKRD's Avatar
key word, little while. I know N20 loves high compression. I'm just saying that motor was built for a N/A setup. If he wanted to run a big shot, should have set it up that way. Just my own .2 cents
Old 08-05-2006, 03:13 PM
  #74
9 Sec. Club!!!
dan03mach's Avatar
And what way is that?? Whats the difference?
Old 08-05-2006, 03:15 PM
  #75
WizeAss's Avatar
i am driving it... the issue is the rear aint centered anymore.... it is to the passenger side....
If you lower your car GET RELOCATION BRACKETS.... take my advise.... too bad the car came this way.... If I only was aware that they are necessary.
Old 08-05-2006, 03:17 PM
  #76
TINKRD's Avatar
gap the rings more. I'd also go w/ a lower compression, pistons specifically made fore nitrous , heads studs for sure
Old 08-05-2006, 03:18 PM
  #77
WizeAss's Avatar
10.5:1 or 11:1 is perfect for nitrous... 12:1 is a little high.... he needs to cut the timing a bit...... atleast he will get a full burn with all that compression!!!
So Germ.... bottle in a bag??
Old 08-05-2006, 03:33 PM
  #78
Adjustable panhard bar will fix that..
Old 08-05-2006, 04:22 PM
  #79
Elite_Hot_Rod's Avatar
Relocation brackets and LCA's have nothing to do with the rear end moving from side to side. LCA's move the rear forward and aft in the wheel well, the pan hard rod moves it from side to side.
i am driving it... the issue is the rear aint centered anymore.... it is to the passenger side.... If you lower your car GET RELOCATION BRACKETS.... take my advise.... too bad the car came this way.... If I only was aware that they are necessary.
Old 08-05-2006, 04:56 PM
  #80
01 Red WS6's Avatar
Let me know if you all go, I might be down to head out
