trans cooler
Old Nov 9, 2006 | 08:25 PM
volcanic2345's Avatar
Default trans cooler
where do yall put yall trans coolers on your car at? (2002 camaro)
and is a transmission guage hard to put in and water guage thanks!
Old Nov 9, 2006 | 08:31 PM
V6 Bird's Avatar
I usually install mine on the rear of the car like a rear turbo setup goes...gets alot of under car air that way.
Old Nov 9, 2006 | 10:22 PM
Paul's_03SVT's Avatar
in front of the radiator/a/c condenser
Old Nov 9, 2006 | 10:36 PM
skipperbisket's Avatar
front of the radiator...last one i did is mounted just under the hood latch....just make sure you get the hoses proper length and tightened real good. 405HPTA had one blow off a week or so ago when he didn't tighten it properly.
Old Nov 10, 2006 | 10:19 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Plus one and mine has an automatic switch that turns on the 900 cfm fan at 150 degrees. No gauges for me.
Old Nov 10, 2006 | 11:49 AM
any pics of how the fan is setup? would like to see that.
Old Nov 10, 2006 | 07:40 PM
yeah you got any pics
Old Nov 10, 2006 | 09:32 PM
I'll take some tomorrow. Steve from http://www.pt-motorsports.com/ did the install.
Old Nov 10, 2006 | 11:31 PM
FUroundeye's Avatar
With the overheating issue you were having I would've expected you to mount it in the rear, but it sounds like you might have that problem taken care of anyway What model of cooler are you using?
Old Nov 11, 2006 | 08:55 AM
Perma cool with the 900 cfm fan. I bought it from one of the 2 companies that send out catalogs every month.
Old Nov 11, 2006 | 09:15 AM
JMBLOWNWS6's Avatar
I put mine in the Drivers side fender. It gets air cooling from the incoming air below the blinker light on my TA. Then I cut a nice little circle out so the puller fan can come on @ 168 Look pretty dam nice with everything mounted in place. Used a painless wiring harness kit for it and changed out all the fittings on the 4l80 to AN Ill snap a pic of it when I get home
