This sux
Old Dec 18, 2006 | 05:29 PM
1low01's Avatar
Default This sux
Just got my car on friday. Went to the track last night and I had to take it back to carmax to get the stereo fixed and when I pulled up I heard a very bad noise in the rear end. So I just got off the phone with them and the rear end is shot. I really hope this is not a long process to fix. Anyone else had the problem?
This makes me
Old Dec 18, 2006 | 05:32 PM
SEB's Avatar
SEB
Sounds like you got ripped off.
Old Dec 18, 2006 | 05:46 PM
Rob's 02 SS's Avatar
Damn that sucks i bought my car from car max no problems but a water pump leak and i replaced the waterpump.
Old Dec 18, 2006 | 05:50 PM
1low01's Avatar
Thanks!
Old Dec 18, 2006 | 07:17 PM
bud8fan's Avatar
at least they should be fixing it under warranty right....
Old Dec 18, 2006 | 07:35 PM
1low01's Avatar
yes they are. I also got the extra warr.covers the car up to 100k. i AM JUST WORNDING HOW LONG IT WILL TAKE THEM TO FIx it. Any guesses?
T
Old Dec 18, 2006 | 07:49 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Just depends on what is broken and if parts are in stock locally. Most likely it is your posi unit, possibly the gear set. Figure 2 days if they aren't wasting time getting parts.
Old Dec 18, 2006 | 07:57 PM
1low01's Avatar
I hope only two days that would be great.
T
Old Dec 18, 2006 | 08:53 PM
gr8one99SS's Avatar
i bought mine at the carmax behind texas stadium(dallas), it also had rear end noise, good luck it took them 5 times before i made them pay another dealer to do it right. Hope you luck is better, it usually takes 1-2 days depending on parts.
Old Dec 18, 2006 | 09:06 PM
Humanoid's Avatar
This is my opinion and opinions are like **** holes...everyone's got one.
If you race and **** breaks....dont be suprised because thats part of it.
A good way to keep your car from breaking is not to launch it on a sticky drag strip
Old Dec 18, 2006 | 09:25 PM
1low01's Avatar
5 times huh? Boy that sounds like chit. I hope I have better luck also.
If not
Old Dec 18, 2006 | 09:28 PM
1low01's Avatar
The strip it what makes it fun. Just think I need to let it cool off a lil between races next time.
T
Old Dec 18, 2006 | 09:29 PM
Splitz's Avatar
where is the posi set, how much is one, and how hard is it to replace in my garage?
I've got real bad wheel up, torque doesn't seem to be being equaled out in the rear properly.
Thoughts?
Old Dec 18, 2006 | 09:47 PM
Elite_Hot_Rod's Avatar
It has nothing to do with letting it cool off, stock 10 bolts suck.
QUOTE=1low01]The strip it what makes it fun. Just think I need to let it cool off a lil between races next time.
T[/QUOTE]
Old Dec 18, 2006 | 09:48 PM
The posi is in the rear end in the pumpkin and no you don't want to mess with it if you don't know what you are doing.
Thoughts?
Old Dec 18, 2006 | 09:52 PM
Splitz's Avatar
grrr....most shops that a $600 swap job! *shrugs* guess I'll live with the wheel hop for now!
Old Dec 18, 2006 | 10:14 PM
LSXNV's Avatar
if you are just swapping out the posi, it is not that hard. jack it up, pull the pan, pull the axels. unbolt the carrier caps while keeping the shims in order. unbolt the ring gear from the carrier and swap to your new unit. then put it back together putting the shims back where they go. check the back lash with a dial indicater and shim as needed. most gear companies can send you specific info on the swap or get a book from a parts store. no real challenge back there unless you have to remove the pinion (gear swaps).
Old Dec 18, 2006 | 10:42 PM
02ss98C5's Avatar
Don't tell them you took it to the track then that warranty would be voided and they would tell you sorry.
Old Dec 18, 2006 | 10:46 PM
BizZzatch350's Avatar
Moderator
Well, least you have a warranty, when **** breaks on my TA, its just reason to mod it more.
Old Dec 18, 2006 | 11:20 PM
01WS6/tamu's Avatar
With it being christmas and all if they have to order stuff and it's not available locally don't look to have it back until the middle to the end of next week. Our parts situation and ups through our shop right now is absolute crap. We have cars tore down everywhere and no parts or incorrect parts are killing us.
