Nitrogen in your tires???
When I checked it they were at 90psi
ive been told it rides smoother with nitrogen
- a 2% increase is pretty marginal to me (even if you get 30 mpg, that would mean you'd see a .9 mpg increase)
- if one monitors their tire pressure once in awhile, why couldn't you get the same tire life with plain jane air? It's the tire pressure that dictates the treadwear, not the fill substance. If you keep your tire pressures at what is desired, you should have the same tire life regardless of which substance.
- $20-40 for nitrogen fill = 25-50 pumps at the corner store, if not free (I usually only need to fill mine 2-3 times a year).
- smoother ride probably due to placebo effect
- even if it is "lighter" I highly doubt it has any real world benefit, the weight differential in a plane jane air tire and a nitrogen tire can be considered neglibible. If it were a 2-3 lbs difference, that might do something for you.
just some thoughts
It begs the question: the girls would have blown up or the tires?
I have heard about the whole nitrogen thing from many long haulers over the years. The difference is the rating of the tires - if you are driving a V rated tire then you *may* get better wear, mileage, handling but an H will be so negligble it wouldn't be worth it.
Guess how many cars on the road drive on H rated tires?
Nitrogen will leak out of the tire slower due to its larger molecules. This results in less maintainence which results in less $$$, also helps prevent tire failure due to excessive wear caused by under inflation.
The reason nitrogen is used as a tire fill in race cars is not due to the nitrogen not heating up as the tire does, but because if you use pure, or close to pure nitrogen, the expansion rate can be better quantified. For example, if you know your tires are going to heat up to 200 degrees, you can calculate pretty accurately how much of an increase in pressure will result from the temp increase from ambient. If the tire was filled with regular air, your estimate of the increase would be much less accurate, due to the other unknown impurities in the air.. Oxygen, moisture, dust, etc.
Nitrogen molecules are larger and permeate the tire at a slower rate. Maybe after 2 or 3 years of sitting without any air pressure checks, the tire might be down a few pounds.
Industrial grade nitrogen is 99% pure. The other 1% is inert. But ... there is 0% moisture. Compressed air has a LARGE moisture content ... less in arid climates and more in humid climates. It's why we have to drain air compressor tanks occasionally.
It's not the gas itself, but the lack of moisture. A tire will generate heat from rolling resistance. Moisture inside the tires causes the air pressure to increase to higher pressures. I have seen pressures go from 30psi to 45psi using compressed air.
Nitrogen heats up as well, but not as much.
2 benefits ... it's predictable and one can start out on higher initial pressures. In a racing environment, I go into turn 1 with my tires closer to operating pressures and better grip. I typically start out with 25psi cold and come off track reading in 31psi
Finally, with a moisture laden environment, that is constantly being heated and cooled, it can cause wheel corrosion.
I have nitrogen in all my race tires, bike tires and trailer tires. Race tires for obvious reasons, but the bikes because I don't want a wide variance in air pressures for safety reasons. They are in the trailer tires because they sit stationary for long periods of time.
It also helps that Natwell Welding supply in San Antonio is one of my sponsors.
now thats funny! how much psi will it take to blow up the tire?
it takes alot to actually blow up a tire, we get them pretty dammed high to seat beads on low-pros
low pros SUCK to mount man, i feel your pain. i had some guy blame me for putting 110 psi in his 80psi truck tires. not only did i NOT work the last time he was in, but it was when we were using a backup compressor that did not exceed 90 psi because the main one threw the belt.
