Water pumps
Water pumps
My water pump started leaking fluid through the front of it. Is this a common problem with ls1 water pumps? I have the new one on and it is fine I just did not know that was something I would have to replace.
Thomas
Thomas
Like mentioned, its a sign that the WP is on the way out. I would replace it immediately. From my experience, some leaking WPs perform normally while other might die immediately. If you have to drive it, keep your eye on the coolant temp.
Ryan
Ryan
Ryan
Ryan
Dick
If you drive the car forever, you will eventually have to replace every part. Moving parts have a lifespan..you water pump being a moving part, will only last so many operating hours. Electrical parts are the same....they won't last forever.
