Bad O2 Sensors
Old Jan 25, 2007 | 02:34 PM
str8_4rm_dabronx's Avatar
Default Bad O2 Sensors
I was under the car doing a oil change and cleaning and notice my o2 sensors looked burned. Will this pull a SES? I want to get headers should I wait to change them or just change them now? Any one know where I can get some?
Old Jan 25, 2007 | 03:01 PM
SHINER's Avatar
wat exactly do you mean that they looked "burned"
were they dirty? That would make sense cause they ARE under the car.
Is your car already throwin codes? Running shitty?
NEED MORE INFO THAN THIS!
Old Jan 25, 2007 | 03:15 PM
The car seems to be running ok. I got a ses this morning on the way to work and planning on going to advance auto parts to check it out. I wiped around the sensors thinking it was dirt but it wasnt coming off.
Old Jan 25, 2007 | 03:22 PM
1320FEVER's Avatar
Its probably just carbon. Just spray some carb cleaner on 'em and put 'em back in.
Old Jan 25, 2007 | 03:23 PM
SHINER's Avatar
before anything just get it checked out
Old Jan 25, 2007 | 03:28 PM
Thanks guys. I will and give an update. Can they go bad?
Old Jan 25, 2007 | 03:32 PM
SHINER's Avatar
Anything can go bad.
Old Jan 25, 2007 | 03:35 PM
Know how much to replace them?
Old Jan 25, 2007 | 03:38 PM
SatanzWS6's Avatar
just pull em off and shake em. if you hear a rattle come from the inside, they are bad.
Old Jan 25, 2007 | 03:40 PM
pdanrichey's Avatar
$65 or so I think...? Look for some to buy from guys on here. They're going to look burnt, you're pumping a ton of exhaust over them everytime you turn on the car.
Just leave them alone! If the car is running right and the SES light isn't on...why bother?
thanks.
