Working on a LT1, need some info.
Anyhow, my question is, should I buy a factory radiator or just get one from the parts store? Same with the head gaskets? I brought this subject/question up because this has come up with LS1s. There are tons of claims not to use the gaskets that come supplied with aftermarket headers, to use the factory stainless steel set. I figured this may apply to LT1s.
Thanks.
I asked both Oreilly and Autozone what the brand of head set and they said Felpro. The radiator from Autozone was a Trans Po and the one from Oreilly is a TPR.
Radiator doesn't matter as long as it's reverse flow. I'd go with the 1406 header gaskets as well.I would however recommend using the GM LT1 specific RTV for the ends of the intake gasket. It's dries as hard as concrete and is about the only thing I've found that doesn't leak.
The torque specs on a 1995 or earlier is 65 Ft-lbs on the head bolts.
Tightening the intake manifold:
Step 1: tighten all bolts to 71 in-lbs
Step 2: retighten all bolts to 35 ft-lbs
Sorry for the kindergarden intake drawing. Hope this helps.
Joe
ive said that one be4 too
25 opti sparks later here i am
Does temperature rise when its stationary? I took the car out for a run and it held at the 1st mark the entire time which should put the temperature at 185 degrees. Now I stopped, got out of the car, walked around it, and a couple of minutes later, the temperature got all the way up to the 3rd mark. Then the fans kicked on. What's the temperature that it must reach before the fans kick on? From the gauge, it has to be over 200 degrees and personally, I don't feel comfortable giving this guy's car back. It shouldn't fluctuate that much by coming to a stop for a short period of time. I know there isn't any air moving across the radiator when at a still, but seems like it generates a lot of heat. When the fans do kick in, the temperature slowly goes down. Letting the engine get that hot too often to me makes me think that it would have a bearing on the engine's life.
So again, is this normal?
