FS/FT BoosTeD 95 Nissan 240sx - DFW
995 240sx Base Model (4 lug converted to 5 lug)
Power windows, Locks
Redtop SR20det with 74k miles on it
ENGINE
All Parts Purchased Brand New
Garrett GT2871R .64
Taka Steel Braided Lines
Heavy Throttle Coolant Hoses
S15 metal exhaust manifold gasket
S15 metal turbo to manifold gasket
OEM Nissan Front Main Seal
OEM Nissan Rear Main Seal
OEM Nissan Valve Cover Gasket
Oil Pan Resealed
Mobil 1 10w30 Motor Oil
New Z32 Turbo Studs on Manifold
New Hardware for everything connected to turbo
Engine Bay Resprayed Black
Koyo 3 Core SR Radiator
S13 Electric Fans
Stock SR Fanclutch and Shroud
Custom Intake by Matchless Performance
HKS MAF adapter
HKS Cone Filter
Greddy Type RS BOV Recirculated
Custom Huge Core FMIC Kit Good for 400+
Custom Hotpipe
Custom Coldpipe
Topspeed Turbo Elbow
Topspeed Downpipe
Topspeed Test Pipe
Topspeed Catback Exhaust
TRANSMISSION
Exedy 3 puck Clutch
New throwout Bearing
New pilot bushing
New pivot fork
New slave cylinder
Resurfaced SR flywheel
Mobil 1 80w90 Gear Oil
SUSPENSION
Tokico Blues
Eibach PRo Springs
New OEM Steering Rack
New Moog Outer Tie Rods
New Moog Inner Tie Rods
Tanabe Front Swaybar
Custom Tension Rods
New OEM Front Lower Control Arms
Front Strut Tower Bar
New OEM Rear Lower Control Arms
Tanabe Rear Swaybar
Custom Rear Upper Control Arms
Custom Rear Toe Arms
Subframe Spacers
Custom Polyurethane Motor Mounts (Solid)
Custom Polyurethane Transmission Mount (Solid)
5 Lug swap
96’ J30 VLSD
Mobil 1 80w90 Gear Oil W/ Viscous Additive
BRAKES/ WHEELS
Goodrich Steel Braded Lines
Brembo Drilled and slotted Rotors
Hawk HP + Street/Track Pads
Dot 3 High Boiling Point Brake Fluid
INTERIOR
Project Nissan Drift ****
Momo Aluminum Racing Pedals
GAUGES
Autometer Sport Comp II 30psi Boost/Vacuum Gauge
Autometer Sport Comp II Full Sweep Electric Water Temp
Autometer Sport Comp II Full Sweep Electric Oil Pressure
Autometer Oil Pressure sending unit
Autometer Water Temp Sensor
Greddy Water Temp Inline Adapter
AUDIO
Kenwood Head Unit #KDC-MP528
Mp3/WMA capable
Polk Component 6.5” Door speakers
Rear OEM Chevrolet Bose 6x9”
Stock Amp Wiring Mod
![](http://i24.photobucket.com/albums/c36/jzenki/240sx/DSCN0433.jpg)
![](http://i24.photobucket.com/albums/c36/jzenki/240sx/DSCN0437.jpg)
![](http://i24.photobucket.com/albums/c36/jzenki/240sx/DSCN0438.jpg)
![](http://i24.photobucket.com/albums/c36/jzenki/240sx/DSCN0440.jpg)
![](http://i24.photobucket.com/albums/c36/jzenki/240sx/DSCN0447.jpg)
Wheels pictured sold- Includes stock 300z rear wheels and full set of 4 240sx se wheels and tires
Small things that are noted*
*Has A/C but need to make custom bracket to fit compressor on block
*Power steering pump starting to whine
*Needs to be tuned for more power (Need larger injectors 550c+, a 300zx maf sensor, and ROM tune on the ECU)
*Whole motor was Resealed less than 7k miles ago
*No Leaks
Entertaing all offers for trades as long as vehicle to be traded is manual and not lt1 powered
Will trade + cash (on either end if needed)
Or sell outright for 11k obo
Car is located in Plano, TX
Contact me via PM for faster response or email at jzenki@gmail.com
ENGINE
Garrett GT2871R .64
Oil Pan Resealed
S13 Electric Fans
HKS MAF adapter
HKS Cone Filter
Custom Hotpipe
Custom Coldpipe
Topspeed Downpipe
Topspeed Test Pipe
TRANSMISSION
Exedy 3 puck Clutch
New pilot bushing
New pivot fork
New slave cylinder
SUSPENSION
Tokico Blues
Eibach PRo Springs
Custom Tension Rods
Tanabe Rear Swaybar
Subframe Spacers
5 Lug swap
96’ J30 VLSD
BRAKES/ WHEELS
INTERIOR
GAUGES
AUDIO
Mp3/WMA capable
*No Leaks
Originally Posted by DSIM
Any other interior shots? How many miles on the chassis/odometer?
Originally Posted by Morbid
How much power is the car making right now? Any track times?
Turbo is good for 450whp with supporting mods
