Htown inspection question/help
Old May 8, 2007 | 04:31 PM
glr0212's Avatar
Default Htown inspection question/help
My computer is throwing an 0704 code for clutch circuit failure. I have no idea whats causing it, nitrous window switch, clutch switch or whatever but i have been told they will not pass the car because the SES light is on even though i know there are no other codes being thrown.
If i reset the PCM right before i go into inspect the car will they pass it or can they tell that there is still a fault in the system and still fail the car? Does any one know? I'd rather not find out the hard way?
thanks guys
Old May 8, 2007 | 06:04 PM
SILVER SS 00's Avatar
if you reset the light it will still be in memory,it needs to be driven atleast 100 miles
might be able to help
Old May 8, 2007 | 06:07 PM
nickdotcom's Avatar
how about nitrous? can you pass with nitrous?
Old May 8, 2007 | 06:42 PM
as long as there is no codes for sure
Old May 8, 2007 | 06:52 PM
glr0212's Avatar
I can pass a lot of things very quickly when i press the button thats for sure.
Old May 8, 2007 | 07:09 PM
nickdotcom's Avatar
thats badass
Old May 8, 2007 | 07:22 PM
but are they moving as well
