Help........tons of codes........
Old Jun 1, 2007 | 09:53 PM
BADBOYZ28's Avatar
Default Help........tons of codes........
Well this is whats going on!! To make a long story short my damn car wont start. Its started off my missing alot then after a few days it just stopped turning on. It just cranks over and over!! I'v hand problems with the crank sensor before so I just assumed it was that. So I replaced it with a new one but it still does the same thing. I'v done a few searches and checked the main things.
1) fuel pump turns on and there's fuel @ the fuel rails
2) Ignition relay is good I'v swapped them around and they work fine
3) All the fuses are fine non of them blown
There's is NO spark at the plugs on either side and I have a ton of codes here's the list hopefully someone can help me out PLEASE!!!
P1637 - Generator L terminal circuit(been there before problem)
B1001 - Option Configuration Error
U1000 - Class 2 communication malfunction
U1300 - Class 2 short to ground
U1016 - Loss of class 2 communication with VCM
U1040 - Loss of class 2 communication with ABS
U1096 - Loss of communication with IPC
Old Jun 1, 2007 | 10:08 PM
LS1x2's Avatar
Formerly 4mulaJoe
coil packs? Grounds on the back of the driver's side head? That's just a couple things I would check.
Old Jun 1, 2007 | 10:29 PM
Inspector12's Avatar
TT-TECH Veteran
Exactly been there made that mistake before.
Old Jun 1, 2007 | 11:38 PM
BADBOYZ28's Avatar
I checked with a tester light to see if the coil packs had power and they were getting power. If the ground was bad do think they would still have power? I'll check it out tomm either way doesnt hurt!!
Old Jun 3, 2007 | 03:42 PM
BADBOYZ28's Avatar
Haven't had a chance to check all the grounds yet. But do you think my pcm/ecu might be fried??
