SSBC Brake Install Special @ G-Force!!!
I just put on new rotors and pads for my 02 Z28. The pads squeal absolutely terribly. Do these pads squeal or squeak? How much for new pads, install, and lubing the caliper pins(they probably need it)? thanks
-Chris
-Chris
Originally Posted by Mike TexaSS
Did you get your car last night?
Thanks for the use
8 Sec Tuner
Originally Posted by K.T.
Mikey! Can you get me a quote for front calipers for the 03 stang?
SSBC makes both 3-piston and 4-piston calipers for your 'stang, but they are designed to fit their 13" rotor.
4piston with the 13in rotors then please!
