texas heat
Old Jun 25, 2007 | 04:16 PM
gr8one99SS's Avatar
Default texas heat
anyone in dallas texas have a h/c ls1 that dosent overheat with a/c on? I have tried lowering fan setting , water wetter and no luck so far. When it gets 90 plus temps i cant even think about using the a/c . My temps are about 195 with no ac on the freeway and 200-220 in traffic? Whats the best thing to do ? Becool radiator? better fans? please help me out , i tried the search but havent had much luck. On a side note the plugs look good and car runs great but wont stay cool in the summer and cant use a/c at all in traffic.
Old Jun 25, 2007 | 04:19 PM
Strini SS's Avatar
H/C here car runs like a Champ with A/c blowing cold as fck !!!... IMO I would bring it down to Houston to site sponsor to look over the car.
B
Old Jun 25, 2007 | 04:21 PM
gr8one99SS's Avatar
what are your fans set to and whats the highest temps you see?
Old Jun 25, 2007 | 04:26 PM
Strini SS's Avatar
Not sure what the fans are set to, but it has been cahnged with my tune from MTI. Temp has stayed the same from when the car was stock.(Still running stock thermostat).
B
Old Jun 25, 2007 | 06:00 PM
gr8one99SS's Avatar
how do you monitor temps? aftermarket guage? auto tap?
Old Jun 25, 2007 | 07:07 PM
LS1x2's Avatar
Formerly 4mulaJoe
Did you just do the head install? You need to let it idle with the radiator cap off for a LONG time sometimes to let all the air get out of the block. My car also runs about 178 in the heat with AC on. I have a 160 stat and set my fans according to the instructions on there, I can't remember what they were.
Old Jun 25, 2007 | 07:53 PM
WS6NIGHTMARE's Avatar
Its not overheating. Thats normal when sitting still. Unless it really shoots up and you get a "check gauges" light, you're OK.
Old Jun 25, 2007 | 07:55 PM
Pwebbz28's Avatar
If you are using the stock gauge and your car is a 99+ the gauge is an idiot light with a needle. It only moves when the car is cold or hot. I had a 160 stat with fan temps turned down and it stayed right in the middle of the gauge. I put a 160 in my 98 vette and the gauge actually moves all around. Gm changed this because they thought the customers would think something was wrong seeing the gauge move around so much
Hook the car up to a scanner and you'll see its not overheating.
Old Jun 25, 2007 | 08:21 PM
gr8one99SS's Avatar
i am using efilive to monitor and the heads have been on the car for a year. had issues last year but it got worse this year and it not even that hot yet. Think my radiator may be bad? All last year in the summer time i used about three bottles of water wetter and distilled water till the winter hit. I just seems to hate the heat. Will a becool radiator help? better fans? I would like the car to run 180 or less at freeway speeds with the a/c on and no more than 195 in traffic. Is this possibe. I was wondering if bypassing the stock trans cooler and run only the supercooler would help. My trans temps hit 180-195 when the car goes over 210 on the coolant... Any thoughts or suggestions
Old Jun 25, 2007 | 08:41 PM
Ya, that its running at a normal operating temperature, especially how hot is in Texas. Of course a better radiator will be more efficient.
Old Jun 25, 2007 | 08:46 PM
SUTTERERMAN85's Avatar
when i did my cam swap a while back there was a lot of **** inbetween the radiatior and condensor. might be something blocking the airflow. just an idea.
Old Jun 25, 2007 | 09:20 PM
gr8one99SS's Avatar
i have also checked for something blocking flow but its fine.
Old Jun 26, 2007 | 03:34 AM
Pwebbz28's Avatar
Take all the water wetter out and use what you are sposed to. 50/50 mix of antifreeze and water. Completely flush the system, its not hard at all. Then start checking your fan speeds. The vette runs at around 185-190 on the highway in 90+ Are you using a underdrive pulley?
Old Jun 26, 2007 | 08:05 AM
LS1x2's Avatar
Formerly 4mulaJoe
You don't need a bigger radiator. If you have a 160 thermo and the fans set you should be running cooler than that. You need to find what is wrong.
Old Jun 26, 2007 | 08:35 AM
gr8one99SS's Avatar
i have taken it to get flushed and watched the guy do the work myself and still no luck. I think it may be clogged or trashed, hell the car would go past 220 with the 160 stat even before the h/c were done. I have pactically got my fans to turn on at 130 and stay on all the time and it still dont help.
Old Jun 26, 2007 | 08:41 AM
gr8one99SS's Avatar
i agree that something is wrong but the belts are good, fans work, system was flushed, hoses seem normal? What else coud it be? How do you know if you have a bad stat or radiator. In the cooler months (below 80) the car never goes past 180 even with the a/c on. but come spring time and im screwed
Old Jul 7, 2007 | 11:47 PM
Mentu13's Avatar
I have pretty much the same problem. Did you kind the problem?
Old Jul 8, 2007 | 12:17 AM
FIREHAWK #07's Avatar
both fans working??? Check the 3 relays... they're under the hood, in the relay box.
Check them by putting the 'cooling fan' relay into the 'fog light' relay spot... then check to see if your fog lights turn on.... I had a bad relay in mine and that solved the problem....
Old Jul 8, 2007 | 12:19 AM
ex-SS-ve's Avatar
used to have the same prob. but i got a 98 pcm . stock setting was high speed fans on at 236 degrees. it got up to 230 one time and i did the fan mod and a 160 stat. wired them to come on with ignition. now the temps never get over 180 degrees in dead stop traffic and 170 degrees on the highway!
Old Jul 8, 2007 | 12:42 AM
2MuchRiceMakesMeSick's Avatar
it sounds to me like you have a clogged radiator or air in the system
how hot is it with the a/c on?
how many miles you got on your car?
