converting 2wd to 4wd on a silverado?
Old Jul 18, 2007 | 04:26 PM
Reznor's Avatar
Default converting 2wd to 4wd on a silverado?
i wound up with my truck by chance/oppurtunity (took over payments). i was wondering how much work would be involved in converting it to 4wd? main problem is accelerating when it's raining or slick. i really hate having to wait for the tires to grab since the bed is so light.
Old Jul 18, 2007 | 04:35 PM
TEX02SS's Avatar
its a lot of work. transfer case, front differential and drive shafts as well as all different suspension. not to mention on an 04 you will probably have to change out a lot of the electronics. I don't know much, but I know its an involved process. It would be cheaper and less of a hassle to sell your truck and buy a 4wd one.
mcowart's Avatar
quite a bit of work...if i remember correctly and pretty expensive...i dont remember the exact stuff you have to get...it was a long time ago when i helped a buddy of mine look into it.
mike
Old Jul 18, 2007 | 04:37 PM
_Zac's Avatar
TECH Pimp
Not worth it at all.
Old Jul 18, 2007 | 05:22 PM
Tootall's Avatar
regardless it's expensive. It's usually done to off road trucks only. Then it's call a solid axle swap.
Old Jul 18, 2007 | 05:26 PM
Phil8616's Avatar
Does it have a locking rear diff.?
Old Jul 18, 2007 | 05:54 PM
LS69TA's Avatar
Go easier on the throttle when it's wet/slippery. Problem solved. You don't need 4wd on the street anyway.
Old Jul 18, 2007 | 07:06 PM
Inspector12's Avatar
TT-TECH Veteran
Well you didn't even specify the make or model so it would be pretty hard to give you a good idea of cost even if it was feasable, but most of the 4x4 frames are a little larger/taller so it makes it more difficult and the front suspension tie in points are not in the same place or even there at all depending on the truck etc... Sell it and buy a 4x4 if you need/want one.
Old Jul 18, 2007 | 08:37 PM
kerryt1's Avatar
sell it and buy another one if you have to have it. most people who have it never use it....How many Tahoe Z71s do you see carrying soccer moms and how many do you see on the trails.
Old Jul 18, 2007 | 11:26 PM
TXjeepTJ's Avatar
jack it up and put some 38''s on it! (that should weigh it down a little)
Old Jul 19, 2007 | 12:19 AM
camAro242's Avatar
my bros 93 chevy blazer (b4 they changed the name to tahoe) sitting on 3in body lift and 34in mud terrain tires
Old Jul 19, 2007 | 12:32 AM
GunshotZ28's Avatar
Put a small spindle lift on it (3"-5") with some 33" BFG All Terrains. I think fabtech might carry one for your truck. Call up 4 Wheel Parts, They have good prices on their tire and rim packages. They also beat their competitors prices. I paid about $1100 for 33x13.50" Super Swampers with 16x10" Pro Comp rims when I had my Z71. That was mounted, balanced and shipped to my front yard.
Old Jul 19, 2007 | 08:17 AM
HotRod68Camaro's Avatar
sounds like a good time for a solid axle swap. there are a few guys that bought 2wd trucks to put the SAS into. It sure as hell isnt cheap though.
Old Jul 19, 2007 | 08:51 AM
MavrikTA's Avatar
TON OF WORK. Actually, seeing as how the truck is so new, Im not even totally sure it has been done yet. Dont even consider it. Find some tractor weights and throw in the bed. Sipe your tires. My advise.
Old Jul 19, 2007 | 09:15 AM
Reznor's Avatar
dang, yea, seems like a lot of work
bigger wheels+tires + tonneau cover may help
Old Jul 19, 2007 | 05:51 PM
1996Formula's Avatar
heres my 94 blazer, out having some fun back home in california
Old Jul 19, 2007 | 07:09 PM
Tootall's Avatar
that bazer is beggin for a lift . . . at least a 3" body
Old Jul 19, 2007 | 07:30 PM
GreatWhiteZ28's Avatar
Trade it in on a 4wd model???? and heyyy...that Blazer ^ changes colors!!
Old Jul 20, 2007 | 02:42 PM
had20z's Avatar
im selling an 03 z71
:0
Old Jul 20, 2007 | 02:47 PM
I see an S-10 in the pic above, looks to be on hyrdo's. but could it be air?
