Will this work?
Old Aug 29, 2007 | 06:10 PM
2001AntiVenom's Avatar
Default PLEASE HELP!!!! Will this work?
I have a 2001 z28 and im putting a new motor in it. My friend has a 2004 chevy truck with a 5.3 in it. Will my patriot stage 2 heads, comp cam, ls6 intake, stock throttle body, and mass air work on his truck. with the conections on the wires and all for the mass air and throttle body?
Old Aug 29, 2007 | 08:05 PM
bump for the night
Old Aug 29, 2007 | 08:28 PM
A-Dub's Avatar
heads will bolt right up.....cam will work, but you may need to check piston to valve clearance depending on the head and cam specs
Ls6 intake will bolt up, but he would have to modify his accessory drive to make it fit. Hell, according to Hot Rod Mag this month, they tested a truck spec 6.0 at Kenny Dutweiller performance and the truck intake made better power than the LS1 or the LS6.
As I recall, the trucks have a larger MAF than the cars. Even if they don't, the Fbody MAF won't work with the computer since the truck MAF has an integral IAT sensor.
Old Aug 29, 2007 | 08:43 PM
alright thanks so much man
Old Aug 29, 2007 | 09:02 PM
Greed4Speed's Avatar
Depending on the cc of those heads, he may lose compression.
Old Aug 29, 2007 | 09:24 PM
ZacLS1's Avatar
Default T body
I think the 04 pickup t body are drive by wire, 01z will be cable
Old Aug 30, 2007 | 08:29 AM
A-Dub's Avatar
I forgot about that, good call!
