WTB: Miscellaneous LS1 Stuff ASAP!
Pics to mike96z@yahoo.com
LS1 oil pan gasket
an oil cap
maybe some good plugs
just the disks for the centerforce II clutch
i need a ls1 accessorie belt, not ac
ls1 hoses
slave cylinder for ls1
o2 sensors
dipstick, not tube
thermostat housing
ls1 oil pan
if i dont have i need these
bolts from pressure plate to flywheel
oil pan bolts
1 bolt to perimeter valve covers
pm me your address and i may come pick up the hoses.
LS1 oil pan gasket
an oil cap
plug wires
a stock clutch or if anyone has just the disks for the centerforce dual friction
ls1 radiator and ls1 hoses
maybe some performacne stuff
also oil pressure sending unit
coolant temp sensor
o2 sensors
dipstick, not tube
flywheel bolts
oil pan bolts
I am not 100 percent sure but the Lt1 is reverse cooling so I dont think the radiators are the same.
ATM-5827
Brand: Auto Meter
Product Line: Auto Meter Phantom Analog Gauges
Part Type: Gauges, Analog
Gauge Style: Auto Meter Phantom
Gauge Type: Oil pressure
Gauge Range: 0-100 psi
Gauge Diameter (in): 2 5/8 in.
Gauge Diameter (mm): 67.00mm
Sweep: 90 degree sweep
Sending Unit: Electrical
Gauge Face Color: White
Gauge Number Color: Black
Pointer Color: Red
Bezel Color: Black
Liquid Filled: No
Sending Unit Included: Yes
Gauge Series: Analog
This gauge will fit perfectly in a Trans Am's AC vent.
Summit sells them for $60 plus $10 handling.
$40 plus shipping.
I will ship immediately, insure, and provide you a tracking number.
I'm located in DFW, TX.
Thanks,
Reason for sale.
I ended up going with a mechanical oil pressure gauge instead.
