How to remove water spots
Old Oct 9, 2007 | 10:15 AM
GOHOME's Avatar
Default How to remove water spots
Does anyone know the secret to getting rid of water spots on the paint? I have seen a few sites suggest vinegar and water mix. Has anyone tried this and if so how are the results. Anyone who has a black car knows how those water spots still stands out after a good wash.
Old Oct 9, 2007 | 10:17 AM
ls1ws9ta's Avatar
use tropicare. detail spray. use the tc3 and tc8. works wonders
Old Oct 9, 2007 | 11:26 AM
Mike96z's Avatar
wax the car, then theyll be gone.
Old Oct 9, 2007 | 12:56 PM
chupr0kabra's Avatar
White vinegar and distilled water. 50/50 mix. It works great. I've been doing this for years.
-Mike
Old Oct 9, 2007 | 04:51 PM
Grimlock's Avatar
-Mike
Does the acidity of the vineger does not take off all the wax even with the diluation?
Old Oct 9, 2007 | 05:14 PM
s.o.m.SS's Avatar
Ive had to do this before and used 3M rubbing compound followed up by a quick detail wax.
Old Oct 9, 2007 | 05:26 PM
sprayedsilss's Avatar
i've had pretty good luck using a clay bar to get water spots off.
Old Oct 9, 2007 | 06:11 PM
Mike96z's Avatar
ive never gotten water spots after a wash when waxing it. If you let the water just dry on the car you will probably get water spots because of the calcium in the water, depending on where you are, depends on how much you have in the water. I usually do a wax as you dry type of thing or just wipe it down with a towel and then wax it rite after.
Old Oct 9, 2007 | 06:47 PM
s.o.m.SS's Avatar
Sorry I thought you meant long time water spots. Once you are done washing the car, take the nozzle off and just let the water come out of the hose. Run it all over the car. This helps the water sheet off and helps with spots.
Old Oct 9, 2007 | 11:53 PM
306 That Could's Avatar
^^^^exactly what I do.....
Old Oct 10, 2007 | 01:19 AM
TheBlurLS1's Avatar
That's what she said...
Then take the car to the carwash and use the spot free rinse, but let it spray for a little while first.
Old Oct 10, 2007 | 04:35 AM
02Z28LS1's Avatar
using a chamois after rinsing will keep the spots off....
Old Oct 10, 2007 | 09:36 AM
the SS show's Avatar
Default mr clean
my car is black. i got tired of having to dry it off when i was done washing it so i tried a few things listed above but by far the easiest was the mr clean auto dry stuff. i got it from walmart for $15. i dont have to dry the car anymore cause it has a filter that the water goes through. no waterspots, cheap, and easy to use
Old Oct 10, 2007 | 10:51 AM
Yes. You will need to re-wax. But if you use a polish to remove them, you'll also need to re-wax. Or if you use a claybar, you'll need to re-wax.
If they don't come off with a regular car wash, you can pretty much count on having to re-wax.
-Mike
Old Oct 10, 2007 | 11:05 AM
Mike96z's Avatar
man ill sell you a mr clean for $5.00, im sorry but that mr clean thing is garbage, i used it a couple of times, its brand new sitting under my sink, it doesnt work very good and has no pressure.
