WTB: LS1 E-Brake
Old Nov 4, 2007 | 06:03 PM
E V I L's Avatar
Default WTB: LS1 E-Brake
My 98 Formula seems to have a faulty E-Brake. Anyone have one in good condition? Thanks
Old Nov 4, 2007 | 06:49 PM
SiL3NtXWS6's Avatar
What portion do you need? I have the handle assembly.
Old Nov 4, 2007 | 06:53 PM
Havok2's Avatar
deadlyz28 has 1
Old Nov 4, 2007 | 08:31 PM
E V I L's Avatar
Im not sure what I need just yet, I am still trying to figure out what the heck is wrong with it!
Old Nov 7, 2007 | 10:08 AM
deadlyz28's Avatar
i have the whole thing
Old Dec 7, 2007 | 09:08 AM
E V I L's Avatar
Anyone have one?
Old Dec 7, 2007 | 11:35 AM
daniel6718's Avatar
ive got about 4 whole ones
Old Dec 7, 2007 | 01:51 PM
deadlyz28's Avatar
i still have one! lever and all! pm offer
Old Dec 7, 2007 | 02:38 PM
96-speed's Avatar
If your Ebrake is not engaging the brakes hard enough, you can adjust it. Essentially, the e-brake on 98+ Fbodies is a drum brake inside of the brake disc. Look under the car and you will see. First, pull the wheel/tire off, then remove the brake discs. You'll see the e-brake shoe. Remove the e-brake shoe and then you can back out one of the nuts that the shoe mounts on.
Its pretty simple and makes much more sense when you're looking at the car.
However, if all you need is an ebony handle, I've got one laying around you can have for 10 bucks.
Ryan
Old Dec 7, 2007 | 03:08 PM
E V I L's Avatar
Ryan
Well please check out my problem....
https://ls1tech.com/forums/general-maintenance-repairs/825392-emergency-brake-faulty.html
Basically the e-brake is perfectly working as long as I hold the button down when pulling it up, but if I try and pull it up without pushing in the button, then it pulls up freely and the button pops out exposing the spring inside. And I do not have ebony interior, the 98 leather color. Hopefully the install is easy.
Old Dec 7, 2007 | 03:26 PM
96-speed's Avatar
I agree with the last poster. You should just be able ot snag another handle assembly for cheap and swap it in.
Pull the center console, remove two 10mm bolts (IIRC) you'll just need a pair of pliers to remove the thick ebrake cable from the assembly. Swap the new assembly in and then bolt it down. You'll be good to go .
Good luck,
Ryan
Old Dec 7, 2007 | 03:37 PM
E V I L's Avatar
Sounds easy enough, I already pulled the console out once and looked at it but could not figure it out. What interior color is the greyish black in the 98? I know it is not called ebony?
Anyone have that color e-brake and local to me (Houston)?
Old Dec 11, 2007 | 09:43 PM
E V I L's Avatar
I sent you a pm Sil3n, and to the guys in the DFW area, if I don't get one by X-mas, I will be in Dallas for X-mas. Thanks
Old Dec 12, 2007 | 01:33 AM
deadlyz28's Avatar
i still have mine but i wont be in dallas for xmas!
Old Dec 12, 2007 | 11:16 AM
E V I L's Avatar
Pm sent! ^
Old Dec 12, 2007 | 12:14 PM
96-speed's Avatar
Evil, the one i have is black is and if it will work its yours for zero dinero $0. Just come and pick it up from me. Merry Christmas from moi .
I at 290/Jones Road.
Old Dec 12, 2007 | 03:22 PM
E V I L's Avatar
PM SENT! Thanks man!!
