Cam Install Tool
Old Nov 24, 2007 | 02:28 PM
02 SS's Avatar
Default Cam Install Tool
Anyone in the DFW area have a JPR Cam Install Tool for rent? Can't bring myself to buy the tool and only use it one or two times. Will leave deposit. I'm in Murphy. Thanks.
Old Nov 24, 2007 | 03:17 PM
Dragaholic's Avatar
9 Second Club NA
Save yourself time and money, go to the store and buy (2) 5/16" dowel rods. Grind flat spots on them, the full length of the rod, and you'll be set. I don't know the length measurement off the top of my head, but it doesn't have to be exactly. As long as it's longer than the length of the block.
You can Paypal me $20 for the tip. JK
Old Nov 24, 2007 | 03:35 PM
TheBlurLS1's Avatar
That's what she said...
I used steel rods. You will only need to grind down the side of one of the rods, the other should slide in no problem.
Cut them a few inches longer than the cam.
Old Nov 24, 2007 | 03:38 PM
Dragaholic's Avatar
9 Second Club NA
When I did the swap(s) on '00 Camaro SS, I only had to grind one of the rods, but when we did the install on my buddy's '98, we had to grind the other rod. Weird. Not sure if the 98 or 99 block is different than the 00.
khaos288's Avatar
i've seen people use reallly thick gauge wire
Old Nov 24, 2007 | 03:55 PM
Bruser's LS1's Avatar
I used the wooden dowls from Wally World. Lot easier to cut and fit. Also they cost like .99 each. I'm in Garland, if you need some help with it let me know.
Old Nov 24, 2007 | 03:59 PM
Dragaholic's Avatar
9 Second Club NA
Yeah, wood dowels will work too, but for any reason there's buildup inside the block, you get one of the dowels stuck, pull on it and it breaks, you're screwed.
Old Nov 24, 2007 | 04:00 PM
He has a good point, So it's your call
Old Nov 24, 2007 | 05:18 PM
Reject's Avatar
yeah just go to the homedepot and buy the metal ones, you'll use them again sooner or later, either on yoru car again or a buddies.
and i always thought i had a retard block cuss i had to grind one side and not the other for the rods!
Old Nov 24, 2007 | 07:33 PM
StngKlr's Avatar
I went to Home Depot and bought mine for like .99 each. Funny thing is I didnt have to grind either one. Oh well it worked lol.
