Motor Swap and Elec...
Old Nov 25, 2007 | 02:56 PM
my number 1 hater's Avatar
Default Motor Swap and Elec...
The motor in my 98 is toast... I have a buddy with a 99ss motor..I know they have different elec. systems . Does that mean i have to change all the sensors??? And are the cam profiles different from 98 to 99ss???
Old Nov 25, 2007 | 03:08 PM
WS6NIGHTMARE's Avatar
I dont think the harnesses are different, your 98 should plug right up I think. I know the ECU's are different, not the whole system. Get this in a tech section, probably have your answers in an hour.
Old Nov 25, 2007 | 03:14 PM
The harnessess are the same.. I ECU's are way different.... Thats why im not to sure about the sensors...repost in a tech section Done...
Old Nov 25, 2007 | 04:41 PM
playtoy's Avatar
Just get the 99 pcm also. Then we will be able to play with the tune on Hp tuners since marshall has and unlimited for that year. When we going to do the swap?
Old Feb 6, 2008 | 11:23 AM
I will be starting the swap this weekend....
Old Feb 6, 2008 | 12:58 PM
LS183G's Avatar
You wont run into any problems.... mine worked out fine and its using sensors off an 01
Old Feb 6, 2008 | 01:16 PM
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
Every thing is the same just put the motor in and leave the harness and pcm alone.
Old Feb 9, 2008 | 04:56 PM
THANKS LS1 tech members...... I will try and get some pics in later on........
