best cleaner on motor
Old Dec 7, 2007 | 06:37 PM
deadlyz28's Avatar
Default best cleaner on motor
gonna be pulling my motor and cleaning it. whats the best thing to use? toothbrush good tool? not gonna paint but want it to look new.
Old Dec 7, 2007 | 09:25 PM
Inspector12's Avatar
TT-TECH Veteran
Best thing to do and I know cause I do it to every persons car that I do installs on etc... Is the car wash. Don't use any engine clean or anything like that just the high presure soap and don't be afraid to get close to some of the heavly soiled areas. just try not to stay right on top of the connections as they are water proof but not to the high presure. And then rinse with high presure water. The presure and hot water at most car washes does an excellent job. The engine degreasers tend to oxidize the aluminum parts so that is why I always stick with the soap. Have fun.
Jeff
Old Dec 7, 2007 | 09:33 PM
Bad_tx_Z28's Avatar
^^^ but you can also go to o'riellys and get some stuff called simple green....it is some bad *** stuff..and so far it hasnt oxidized any of my aluminum parts.
Old Dec 7, 2007 | 09:46 PM
kjvail1204's Avatar
Default Purple Power
I swear by Purple Power, you can get it for $2-$3 a bottle, and either cut it 50/50 or go full on, wear gloves that **** burns if you have any cuts. Spray it on heavy, then wash some of the car, come back spray it off, and do it again. I didn this on my rear end, and belly of my 88 before i bed liner sprayed it. It works great jsut spray it off well,
Old Dec 7, 2007 | 11:44 PM
daniel6718's Avatar
also i leave the motor running when i do the carwash thing...
Old Dec 7, 2007 | 11:55 PM
ex-SS-ve's Avatar
whatever you do stay away from purple power . especially under the hood. made that mistake. my motor looked like a big snowball after it dryed.
Havok2's Avatar
heard water can puddle in places if you spray it donw.
i wouldnt.
ill use simple green or the dollar store cleaner. a buck and same as siple green
Old Dec 8, 2007 | 12:30 AM
daniel6718's Avatar
thats why you leave it running the heat makes it evaporate off of the motor....
Old Dec 8, 2007 | 12:38 AM
TT-TECH Veteran
Look guys do what you will as everyone has there own procedures when it comes to cleaning there cars etc... But I do this to all my cars every time I clean them and I don't leave them running that is a big issue the old school cars and even some LT1 cars had with water getting into the distributer or the Opti spark on an LT1 as they tend to warp up from the constant heat and then they don't seal, but LS1's don't have these issues! Simple grean is some good stuff I use it alot in my mop bucket for cleaning the floors etc...But it is not needed. You can use it in addition to the carwash, but It is really the high presure that does the best work! A water hose at the house with any of these cleaners will not get you even close to what $3 at the carwash can! I know I do both when I can't get to the car wash etc... I use the water hose and it isn't nearly effective.
Old Dec 8, 2007 | 01:45 AM
TheBlurLS1's Avatar
That's what she said...
If it's really gunky, Foamy Engine Brite works WONDERS in combo with a wheel brush. After that, go over again with simple green, then rinse thoroughly. I can't even describe how dirty my Saturn's engine bay was and now it's bling blingin'.
Old Dec 8, 2007 | 06:37 AM
CRAGER's Avatar
Administrator
Go to carwash, turn OFF car. Pop open your hood, stuff towel under the lid where the air comes in so the filter does not get wet. High pressure soap car, underside, engine bay,etc... then high pressure rinse. Done.
Remove rage, I dry up the engine a little, then leave. Its that easy, no chemicals, I've been doing this to my SS for 7 damn years, and about 4 on the T/A.
Peace,
Craig.
Old Dec 8, 2007 | 07:52 AM
deadlyz28's Avatar
im cleaning the motor when its out of the car
Old Dec 8, 2007 | 09:32 AM
Grimlock's Avatar
Most likely you didint do the 'rinse' thingy very well? Kind of like leaving shampoo in your hair after a shower, your head would look like a big snowball as well when the shampoo dries.
Old Dec 8, 2007 | 10:36 AM
2 SLOW's Avatar
I used some cheap autozone stuff
Old Dec 8, 2007 | 10:41 AM
Grimlock's Avatar
You guys dont fret when you get water near the injector packs? That is a good photoshop you did 2 slow. J/k, looks really good, a lot better than what I did by hand only. I just dont want to get stuck where I cleaned the engine bay for fear of getting spray on any wires and shorting something out.
Old Dec 8, 2007 | 10:46 AM
2 SLOW's Avatar
I was just careful where I sprayed the cleaner and that water, it was a two step cleaning, the only warning was to not get any on the belts.
They car had prob. 80K on it and I didn't fell like I was going to damage anything electrical.
Old Dec 8, 2007 | 10:59 AM
kjvail1204's Avatar
I never had this problem, used it all over the engine, the engine bay, the belly, the rear axle. Just rise it good, hell take it it with you to the car wash, spray teh engine down, go clean yrou car, come back soap rise and then water rise, Nice and brite.
If it out of the car, Simple Green, Purple Power, GUNK, any of these will work, but liek above with GUNK, and the like does bad things to alum. I would stick with SG or PP.
Old Dec 8, 2007 | 11:29 AM
Grimlock's Avatar
Spraying the engine bay and not getting the belts wet would seem like trying to **** in a public urinal and not hitting the big dinner mint in the center. What do you do to not get the belts wet? Cover it with plastic?
Old Dec 8, 2007 | 12:06 PM
Black2001z06's Avatar
It looks to me like he covered them with a towel...
Old Dec 8, 2007 | 06:32 PM
Havok2's Avatar
2low: what did you actually use?
