Shorter oil drain plug? Headers blocking current one.
Old Feb 11, 2008 | 04:54 PM
Morbid's Avatar
Default Shorter oil drain plug? Headers blocking current one.
I was wondering if there's a shorter drain plug I can use for my engine oil? The current plug is being blocked by the FLP headers. You think when they designed them, they would have kept something like that in mind.
Old Feb 11, 2008 | 08:40 PM
jlrz28's Avatar
10 Second Fun Car
How about the bfh mod? JK Some other threads talk about grinding it down. How much are you lacking?
Old Feb 11, 2008 | 11:50 PM
mmiller's Avatar
Texas Director
I had the same problem. With the car on jack stands, I just took a long pry bar (used the oil pan for leverage) and gently flattened the header tube that runs by the drain plug. Problem solved.
Old Feb 12, 2008 | 12:05 AM
RickyMartinZ28's Avatar
Gently beat the **** out of it with a big hammer. But be careful not to hurt it.
-Rick
Old Feb 12, 2008 | 12:18 AM
Morbid's Avatar
That certainly sounds like a simpler solution. The drain plug stays in by a couple threads, it feels like it wants to come out but it won't.
Old Feb 12, 2008 | 12:28 AM
chrysler kid's Avatar
thats odd, how did the previous owner get it out?
Old Feb 12, 2008 | 12:31 AM
daniel6718's Avatar
prybar and move the headers outa the way some...then do the opp for reinstall
Old Jul 14, 2020 | 01:41 PM
ss.slp.ls1's Avatar
Do you have poly motor mounts installed?
Old Jul 16, 2020 | 02:26 PM
imma_stocker's Avatar
When you get it out, swap the drain plug for a quick drain plug. Like these guys make https://www.fumotooildrainvalve.com/
These things make for a cleaner oil change anyways, especially sport bikes with full fairings.
Free option is to shave the drain plug head until there's barely enough for a socket or wrench to grab. Shaved bolt sucks if you ever round it out.
