LS1 Backfiring when started and sometimes during running.... wat do you think?
Old 02-18-2008, 08:25 AM
Mike96z's Avatar
Originally Posted by 10SecDreamer
If your timing is all correct, check what your o2s are reading, might be running a lil lean from a vacuum leak somewhere.
ill keep that in mind.
Old 02-18-2008, 08:27 AM
Mike96z's Avatar
Originally Posted by will350wax
well part of your problem is open headers. your 02s arent reading for **** at idel cause your headers are sucking cold air back in. put some exhaust on that thing.
ive ran an LT1 open headers before and never had a problem with it sucking cold air back in and popping, if the car is steadily pumping out air I dont see how a sufficient amout of air could crawl back in and make a big difference. Ive ran it open headers in heat and cold but still same results, ima get the xpipe put back on but dont think that will cure anything, just make the popping a little less louder lol.
Old 02-18-2008, 03:29 PM
chrysler kid's Avatar
i had a very minor leak at the ypipe and it made my car backfire and miss and lose horsepower. put the x pipe on and let us know
Old 02-18-2008, 03:47 PM
Mike96z's Avatar
will do! maybe its just an LS1 thing?
Old 02-18-2008, 09:59 PM
WeeWolf's Avatar
car will run like crap open header sounds good though
Old 02-18-2008, 10:57 PM
i was told that not only does the cooler air cause the back fires but they send faulty signals to the o2 sensors causing the car to run more rich and as a result backfire and sputer more
Old 02-18-2008, 11:05 PM
dshag's Avatar
My guess would be a faulty coil or the ignition controller, i say this because i had a 6cyl, i know 2 completely diff cars but just a thought, it would backfire and have problems accelerating and a coil was burnt out caused by a bad ignition control module...hope this helps
Old 02-19-2008, 01:01 AM
Mike96z's Avatar
Started it up tonight, noticed flames coming out the headers when it popped 3 times. All 3 times there were flames. Sounds like its missing during idle and under load.
wats the best way to test coils?
Old 02-19-2008, 01:09 AM
txh0tb0i972's Avatar
autozone does a test on them! but you have to talk to the right guy! go to the one off of irving blvd 24hr one and talk to fat rodolfo... tell him santana sent ya hell talk **** about my car lol
Old 02-19-2008, 07:22 AM
Pavlock Performance's Avatar
If you have a 98 engine with 98 coil brackets you might have crossed the coils making them fire the wrong cylinder. The coils are labeled to what cylinder they can fire so check your work and see if that is it!
Old 02-19-2008, 09:01 AM
Mike96z's Avatar
they are wired correctly, i know that for sure.
Old 02-19-2008, 05:14 PM
  #32
dshag's Avatar
id say visually inspect them, look for blackened/problem areas, if theres a ses light or has been one on then get it read and it will tell you what cylinder.
Old 03-02-2008, 03:33 PM
  #33
Mike96z's Avatar
Still think its the open headers? here's a vid.
Click here to see Video
Old 03-02-2008, 03:44 PM
  #34
whitehooptie's Avatar
Timing is way the **** off.
Old 03-02-2008, 03:51 PM
  #35
Mike96z's Avatar
what i was thinking, not sure if itd be the timing kit itself or computer tuning issue. i think its more than just being open headers. 100k i think the timing kit needs replacing. Might as well throw a cam in there if its true. Anyone else?
Old 03-02-2008, 05:00 PM
  #36
Unplug the O2's It'll throw a code and stay in open loop but oh well. Pull your cam and crank sensors and make sure there is no trash on them. If I remember right, they are just hall effect sensors so metal shavings could confuse them.
Old 03-02-2008, 05:20 PM
  #37
((((((Administrator))))))
CRAGER's Avatar
Exclamation
100%
Plus your thrashing your o2's as we speak. I see new ones in your very near future.
Peace,
Craig.
Old 03-02-2008, 07:28 PM
  #38
Mike96z's Avatar
i understand this but i dont even drive the car so ruining the o2's wont happen. theyll be okay til i get the exhaust on. i dont even drive it. just start it up about 2 times a week to keep it fresh.
  #39
Mike96z's Avatar
thanks for the input.
Old 03-02-2008, 07:29 PM
  #40
Mike96z's Avatar
ill prob replace them anyways.
Quick Reply: LS1 Backfiring when started and sometimes during running.... wat do you think?
