Synthetic vs conventional
Old Feb 18, 2008 | 05:12 PM
quickblade's Avatar
Default Synthetic vs conventional
This has been a long talked about subject..
I am trying to determine what I would get out of my car running synthetic??
how many of you guys/gals run synthtic compared to conventional?
Old Feb 18, 2008 | 05:15 PM
6THZ28's Avatar
I use Mobil 1 synthetic
Old Feb 18, 2008 | 05:18 PM
mojolamar's Avatar
+1 on the mobile 1 synthetic
Old Feb 18, 2008 | 05:33 PM
quickblade's Avatar
So it looks to be that most peeps use synthtic....
dam that **** is expensive though>>
Old Feb 18, 2008 | 05:39 PM
mmiller's Avatar
Texas Director
IMO Royal Purple > Mobil 1. Just my .02
Old Feb 18, 2008 | 05:40 PM
Brian2006's Avatar
Royal Purple is overrated.
Mobil 1 synthetic all the way
Old Feb 18, 2008 | 05:42 PM
nor-texLS1's Avatar
castrol syntec
Old Feb 18, 2008 | 05:44 PM
quickblade's Avatar
see, dam, this whole time I been on the valvoline conv.
**** seems to work for me...
What is the advantage going with syn? am I going to get better gas mileage, or better wear on the engine?
Old Feb 18, 2008 | 05:48 PM
venomhp's Avatar
I use synthetics in the diffs, regular ole havoline in the engine, on my buddies truck that had like 188k or something like that when we tore it apart it was freaking spotless and that was the only oil that was ever in the motor. so thats what mine has always had.
I chose synthetics in the diffs for less rolling resistance and it runs cooler
I dunno 134k and runs like brand new
Old Feb 18, 2008 | 05:49 PM
I8ASaleen's Avatar
Royal Purple gets my vote, I ran it in my T/A and it held up very well.
venomhp's Avatar
its supposed to be better for the wear on components because it doesnt break down as fast or easy, so there for its a better oil and can help the longevity of your vehicle, gas mileage yes in the diffs, not really much in the engine if anything
Old Feb 18, 2008 | 06:01 PM
quickblade's Avatar
Roger that.. I was inquiring because on my next oil change, I am debating for conv. or syn.
I have always used halvoline and valvoline, since the same peeps...
and have never had an issue, but for the fact I race this car often.
I am looking for what will prolong the life of the engine....
Old Feb 18, 2008 | 06:07 PM
venomhp's Avatar
honestly dude I wouldnt change it from whatever you have been using. you can but honestly if you want to be running synthetics then you need to be running that from the very get go. maybe once you build up your engine or do a head/cam swap or make it a 408?!?!?! Im alyways full of ideas when its not my money! anyway man Id say keep what you got going but thats just me
venomhp's Avatar
also get your peeps to go out to the track on the 29th!!
Old Feb 18, 2008 | 06:10 PM
6THZ28's Avatar
then synthetic is for you but once you go synthetic theres no going back. meaning you can't put conventional in once you've made the switch
Old Feb 18, 2008 | 06:36 PM
quickblade's Avatar
that is something I was kind of worried about.. Once you pay for the expensive, they lock you in at that price.. LOL
meaning no going back... is that because of what the syn. does to the engine?
Old Feb 18, 2008 | 06:40 PM
venomhp's Avatar
Ill write something up more in detail or explain it to you at the races or a meet n greet, my plane is boarding right now for seattle-Mike
Old Feb 18, 2008 | 06:41 PM
dshag's Avatar
i use royal purple, like stated earlier since its synthetic the bonds between the molecules last longer and are more resistant to breaking down. What does that mean? You can go longer in between oil changes mileage wise and time wise. I believe the reason they say 3k or 3 months for conventional is because after continous heating and cooling combined with time it makes it less viscous, but thats just a guess. I personally dont change synthetics but every 5k-10k miles in regular cars or as long as the filter life is, just depends. The old addage comes to mind you get what you pay for...ill do some research and post it up in a bit
Old Feb 18, 2008 | 06:46 PM
Lordsauran's Avatar
I always use Mobil 1
Old Feb 18, 2008 | 06:53 PM
chrysler kid's Avatar
it doesnt matter its all about piece of mind, with that being said i always use mobil 1
