is chirping at 75mph normal?
Old Apr 1, 2008 | 08:23 PM
dshag's Avatar
Default is chirping at 75mph normal?
Well i know these cars are fast but i have been really suprised as of late...i never really got down on my car till the other day and shifting to 3rd at 75ish will chirp the tires in warm weather and my low trac will pop up and they will spin a bit in cold weather...just seeing if this is normal for stockish power? also the tires are raptors that have less then 3k on them...
Old Apr 1, 2008 | 08:25 PM
Sarge_13's Avatar
Well, if a stock V6 Mustang can do it at 60, I'm sure you could at around 75
Old Apr 1, 2008 | 08:26 PM
TXB4Z's Avatar
My old 99 6spd Z28 would do it with the 245-50-16 on it and it was bone stock.
xfactor_pitbulls's Avatar
Dude.........your motor instantly sincs rpms for the gear ratio and speed. Tires do not "lock" the same way. Thats where your chirp comes into play. Just quit doing it.
Old Apr 1, 2008 | 08:27 PM
will69camaro's Avatar
Sex On Wheels
On streets i can spin the tires shifting into 3rd at around 110-115. I don't doubt you're chirping them at 75. Mine is less stock but I remember mild bolt ons only being able to chirp in third.
William
Old Apr 1, 2008 | 08:40 PM
DONAIMIAN's Avatar
KDW's dont chirp on my car
Old Apr 1, 2008 | 08:47 PM
blkbird's Avatar
They did on mine.......
Old Apr 1, 2008 | 08:57 PM
ex-SS-ve's Avatar
hehe speaking of . do you have any pictures of the c6 corvette and the 240 you have. been meaning to ask. just wanna check em out. any specs on either car??
Old Apr 1, 2008 | 08:58 PM
dshag's Avatar
explain maybe im an idiot but im sure the chirp is the tires...
Old Apr 1, 2008 | 09:02 PM
newton's Avatar
Normal on the M6 when you're banging gears. I chirp em going from 2nd to 3rd bangin that shifter.
Old Apr 1, 2008 | 09:03 PM
FIREHAWK #07's Avatar
hadnt seen you post in a while..... you get your 'official license' yet?
Sarge_13's Avatar
PM sent
Old Apr 1, 2008 | 09:07 PM
Greed4Speed's Avatar
You need better tires.
Old Apr 1, 2008 | 09:13 PM
dshag's Avatar
ya finished in under 90 questions not sure the exact number
Old Apr 1, 2008 | 09:38 PM
00pewtertransam's Avatar
ya try slammin into forth gear and breakin them loose thats a little freaky. was meesin around with my buddy one day and that happened to me was a little scary.
Old Apr 1, 2008 | 09:52 PM
Arctic2002ss's Avatar
I have found that it depends on the tires. With the KDW, I could occasionally get a chirp shifting into 3rd. With the GSD3s I have now it will spin for a second or 2 going into 4th @ over 100. Damn Goodyears. My BFG drag radials will only spin a litte hitting second. My car is making about 80rwhp over stock but still.....
BTW, all of these are on the stock size 275/40/17s.
Old Apr 1, 2008 | 09:53 PM
JoeKnowsBaseball's Avatar
I can chirp my 315s going into 3rd with my A4. I got a shift kit. ...and if I'm on a crappy road that's smooth, I can get it sideways in 3rd gear.
Old Apr 1, 2008 | 09:59 PM
dshag's Avatar
just seeing where i stand thats sweet and some of yall are way ahead of me on pwr
Old Apr 1, 2008 | 10:02 PM
chaman's Avatar
My Kumhos have never heard of traction....
Old Apr 1, 2008 | 10:22 PM
Sex On Wheels
That's because your car doesn't run...
Mine are KDWs also (old type) and they spin. I was around 100hp over stock when I was spinning shifting into third over 100mph. It depends on a lot to more than just power. Tire temp, road temp, surface conditions, asphalt type, tire pressure, etc, etc...
William
