Need help
Old Apr 4, 2008 | 05:45 PM
Jaime SS's Avatar
Default Need help
so i was driving home and my car left me
when put the car in drive the car makes a loud grinding noise and does not run and the spedometer is like in 10-15 mph
i can go in reverse but it makes a loud thump noise every foot it moves,
know my question is do you guys think its the rear-end or the transmission
thanks
the reason is because i have warranty on the tranny but the place is like 2 hours from my house, and if the problem was the rear-end then i'd just rather fix it somewhere nearby
thanks again
i need to fix this by the end of this weekend
Old Apr 4, 2008 | 05:49 PM
Jaime SS's Avatar
by the way i did have an issue with rear end it was making a loud whining noise for the past month and told it could have been pinion bearing or carrier bearing
maybe the bearings fell off?
Old Apr 4, 2008 | 06:45 PM
ex-SS-ve's Avatar
check the fluid level. then get under the car and check the driveshaft and rearend. sounds like your clutches are fried in the tranny. take it to g-force and see if they can work with you on warranty terms.
Old Apr 4, 2008 | 10:12 PM
Jaime SS's Avatar
well i just finished towing my car to my house
tommorow after i get home from work i will be checking the gears, and will try to find a shop nearby to get the work done
i will probably give g-force a call
the car only works in reverse, but makes loud clunking noises
Old Apr 5, 2008 | 12:44 AM
chrysler kid's Avatar
i would have someone lay on their belly next to the rear wheels and see if the sound is coming from the middle or rear of the car
Old Apr 5, 2008 | 05:42 PM
Jaime SS's Avatar
just took off the differential cap and theirs about 4-7 teeth missing on the gears
so that means i need some new ones!
any shops you guys recommend nearby sugarland/missouri city
what price is it going to cost me as far as labor?
thanks
Old Apr 6, 2008 | 07:22 PM
Jaime SS's Avatar
well i decided to do the gear swap myself, my dad took off evrything already, is their anything major i should worry about while doing the gear swap?
by the way im putting motive 3.73
Old Apr 12, 2008 | 10:05 PM
Jaime SS's Avatar
just finished my rear end, it turned out good, took me about 7 hours total,
now i found out my tranny crapped out on me aswell.
the car runs in reverse fine, but when i put it in D the car makes a loud whining noise,from the transmission, and speedometer runs at about 10-12 mph
any ideas what it can be?
and maybe price to fix that problem?
the reason is that i have warranty on the trans but the place is like 70 miles from my house and i would have to pay to get it towed there ~$200
maybe if its a small problem i can just get the work done in a transmission shop nearby
what do you guys think i shoul do?
thanks for all the help
Old Apr 12, 2008 | 10:20 PM
Sarge_13's Avatar
Like Joe already said it sounds like the clutches are fried in the trans itself.
