What timing set are you using? Stock? Double Roller?
Old Apr 7, 2008 | 09:40 AM
Mike96z's Avatar
Default What timing set are you using? Stock? Double Roller?
What timing set are you using? Anyone using something like this?
thinking about getting this one.
comp cams
what are some issues with installing something like this?
Old Apr 7, 2008 | 02:00 PM
jdmoore144's Avatar
Double Roller here
Old Apr 7, 2008 | 02:13 PM
Mike96z's Avatar
hard to install? did it in the car or out of the car?
Old Apr 7, 2008 | 02:36 PM
kevin's_00ss's Avatar
was going to go dbl roller but limited funds so went with LS2 chain that should be fine
Old Apr 7, 2008 | 02:42 PM
Krab's Avatar
I went with a rollmaster double roller set-up on my car. No clearance issues with the ASP pulley (f-body, not y-body) and it hasn't given me any trouble since installation.
Old Apr 7, 2008 | 02:48 PM
Mike96z's Avatar
how much did you pay for the LS2 set? you can find the comp cams kits for $100.00. As far as issues, i was referring to installation. Ive heard its hard to get the spacer between the pickup tube.
Old Apr 7, 2008 | 02:49 PM
1970judge's Avatar
We use C5R chains alot as well as LS2. I use Hex-adjust myself.
Old Apr 7, 2008 | 02:54 PM
Morbid's Avatar
The LS2 chain will suffice, it's beefier than the LS1. You can find the timing chain itself for under $40 and the set for a tad over $90 (Texas Speed and Performance.)
Old Apr 7, 2008 | 02:56 PM
Mike96z's Avatar
thats good. Ive heard the LS2 is good but id rather spend the extra $10 and go double roller. More of a hassle to install but I think its worth it.
Old Apr 7, 2008 | 05:14 PM
BigSteele's Avatar
LS2 chain here
Old Apr 7, 2008 | 05:27 PM
Mike96z's Avatar
anyone have trouble installing a double roller?
Old Apr 7, 2008 | 08:09 PM
Greed4Speed's Avatar
It isn't an extra 10 bucks because you can run just the chain ($40) instead of having to buy a complete set ($90).
Old Apr 7, 2008 | 08:17 PM
yea i just replaced the chain.. a stronger chain will be fine, i dont really see see the actual gear breaking on a basic motor setup..
Old Apr 7, 2008 | 08:59 PM
Mike96z's Avatar
well worn gears could be an issue too.
Old Apr 7, 2008 | 09:03 PM
GreenS-10's Avatar
we have the crane double roller on Tams car. I installed it in car and installed a new oil pump with the "red" spring while I had it apart. Didn't even un bolt the oil pan from the motor, just bend a 10mm wrench to fit the pickup tube, and have a magnet handy cause re-installing it will take a couple trys.
Old Apr 7, 2008 | 09:20 PM
Mike96z's Avatar
thanks for the advice.
