Mission:Dyno Tune......Failure.
Yes I understand that I have linked the car back several owners, but the most recent one Tifton will not answer my calls, and said it was tuned by RPM Motorsports in Dallas. I called them to ask about the car and said it took 3 days to tune the car, and had to buy a new PCM for it(meaning Tifton messed something up, and took it to them to re tune it and couldnt do it because the computer had another operating system on it hence them buying a new PCM for it....so now as a conclusion the car was tuned by RPM)
Found a RPM dyno sheet in the glove box the car only has 100shot jets and the car only put down 462 rwhp. It DOES have a nitrous tune, but still thats no excuse for making less power than a LS6 cam.
Car was owned in this order
1-RiddlerLs1
2-Powerhouse
3-Tiffo60
4-SHINER(me)
So Im not trying to bash any buisness here, I just need to find out how I can log into the PCM and retune it properly, cause the last tune was not only horrible but embaressing. I just need to find out whats wrong with the car, not start bullshit drama, ya know.
1-RiddlerLs1
2-Powerhouse
3-Tiffo60
4-SHINER(me)
Formerly 4mulaJoe
You can probably send the PCM in to HpTuners or the ls1 edit guy to get it put back to stock. Then you can have it retuned by a shop of your choice. What was the A/F up top when you said it was so rich?
Id have to ask to be completely honest with you, the tuner just told me it was running fat uptop.
You think a GM tech at the dealership can reflash it, so I can retune it?
Uploaded a EFI log from previous owner.
Try that first... regardless you need to pay for a new tune considering what is all wrong with that one.
Also... as stated, RPM does not use EFILive and it sounds like the original owner tweaked on it a bit, VOIDING any work by RPM.
Cammed LS1s make their power around that range
If my past H/C 141K mile motor can spin 6950 rpms, im sure this 69K mile cammed car can do it aswell.
#32
I had a tune by TRT redone by another tuner, all he did was take it to GM to reflash the PCM and good as new.
so now you make the rules and warranty policies for RPM? don't run your mouth...
#36
You can take the car to a dealership and have it reflashed to factory settings, Then tune it however you chose. I have done this with several cars. One was tuned by RPM and it was tuner locked but they can't lock out a dealership. They will probably charge you a scan charge. I had mine done for $20 but I had a buddy that was the master mechanic there. The other was a new pcm I put in a T/A and just had them flash it back to the VIN on the car body. That's why I tune my own !!! hope this helps. Good Luck
#40
