Shes Back!
Old May 12, 2008 | 06:36 PM
DarkKnightT/A's Avatar
Talking Shes Back!
so i jus got my car back from the dealership and here is the run down of what i got lol i only paid 100 of it cause i have an extended warranty on my car
ENGINE
ROD x1-101.35
BOLT x2-2.62
BOLT x10-25.70
KEY x1-4.25
BEARING x1-20.61
BEARING K x8-258.96
BEARING K x4-155.56
BEARING K x1-38.89
Gasket x1-41.34
BOLT/SCRE x1-5.02
BOLT x8-62.32
GASKET x1-38.75
GASKET x1-23.79
SEAL KIT x1-21.30
SEAL x1-24.53
GASKET KIT x1-82.45
GASKET x2-10.24
GASKET x1-13.92
GASKET x2-43.48
GASKET x1-8.94
GASKET x1-8.94
SEALANT x1-17.30
FILTER x1-5.00
5W30 OIL x6-13.80
GASKET x1-24.27
COOLANT x1-25.07
CRANKSHAFT x1-733.59
SEAL x1-4.92
SEAL x1-7.51
SEAL x2-15.02
REAR END
GEAR SET x1-892.97
BEARING A x1-44.95
BEARING x1-58.23
SEAL x119.43
NUT x1-4.60
BEARING x2-98.16
GASKET x1-10.21
GEAR LUBE x3-95.85
PARTS TOTAL:3163.84 LABOR TOTAL:2234.02
TOTAL TOGETHER:5397.86
Their grand total on their print out is 5787.97
Old May 12, 2008 | 06:57 PM
DarkhorSe_SS's Avatar
sure helps to have the ext'd warranty but if you plan to mod it quick then it ain't worth it. I got ext'd through my bank
What happened to your motor?
Old May 12, 2008 | 06:58 PM
chevyisblue's Avatar
Doesnt modding it void the warranty? You may want to look into that first before you go mod-happy.
Old May 12, 2008 | 07:03 PM
spun bearing.
the warranty doesnt get voided unless the mod you added its the reason it happened i called my warranty people an asked them about that they said as long as it doesnt change how th engine runs lol
Old May 12, 2008 | 07:06 PM
Dude...lol howd it go from $2500 to $5700?
Old May 12, 2008 | 07:16 PM
Originally Posted by DarkKnightT/A
spun bearing.
be very careful with that.. They can turn it around in a heartbeat bro!
I had a differential leak and power window motor went out couple months back. Took it to dealer since on warranty(motor/gaskets) Luckily I got my window motor fixed and warranty did not replace my diff. leak due to I had a dent on the diff. cover. If a warranty rep went out to check my ride I would of lost all my warranty benefits since I started modding
Old May 12, 2008 | 07:43 PM
The way you drive that poor thing too is gonna have you right back in the dealership. Take it easy this time or i see your parents getting ticked off royally.
Old May 12, 2008 | 08:29 PM
mjcotroneo's Avatar
but you didnt have any mods? i was the one that rebuilt the motor in the blue ta at classic buick pontiac gmc
Old May 12, 2008 | 09:11 PM
Morpheus's Avatar
It does indeed. If you go in there with a bunch of mods, the GM Warranty rep will deny the claim and likely void your warranty in case you try to go somewhere else. Bolt ons are usually ok but even that can cause problems with warranty. We have an in-house warranty rep for GMPP at our dealership.
Old May 12, 2008 | 09:30 PM
none on the car you are correct sir
my inquiring was about doing a full exhaust on my car thats why i called them lol
PM(s) sent to MJ
