possible clutch issue?
Old May 12, 2008 | 11:10 PM
JRC2000SS's Avatar
Default possible clutch issue?
today while driving to lunch my clutch pedal got stuck. it was fine goin into first. but when i got n2 2nd and goin towards 3rd the pedal got stuck! i had to mash down on the damn thing and i pulled over. i pumped it a few times in neutral and it was doin the same thing. it would get hung up and the pedal had a ton of play. the pedal would then spring forward very fast after it would get stuck.
t56 tranny, z06 clutch. car has 77345 miles. idk when the clutch was installed due to the fact i bought the car as is bout a year ago. i myself have only put 2500 miles on it since ive had it.
wtf is goin on?
Old May 12, 2008 | 11:14 PM
newton's Avatar
Your master cylinder is being a bitch. Bleed her and see if she behaves. Otherwise kick her out for a new one.
The issue might also be the slave cylinder.
Old May 12, 2008 | 11:15 PM
will350wax's Avatar
Could be hydraulics, check fluid, if black start here.
or master or slave.
Could be weak pressure plate. This was the problem with my car.
Old May 12, 2008 | 11:18 PM
JRC2000SS's Avatar
now i do intend on replacing the clutch sometime down the road. should i just replace the master or slave cylinder?
im lookin at exo from textrailia.
Old May 12, 2008 | 11:29 PM
will350wax's Avatar
If you do a clutch, replace the slave. you are already going to be in there any way, and a slave is around 80 dollars. Now the master I personally would hold off on. You could always change the master later. No tranny pulling required for that.
Old May 12, 2008 | 11:33 PM
JRC2000SS's Avatar
man the bills on this car just keep adding up. im in need of new rotors and pads. now i might have a possible issue with the master cylinder.
Old May 12, 2008 | 11:52 PM
99mongooSS's Avatar
its the master cyl. but I would put a new slave cyl in there too with the miles it has
Old May 13, 2008 | 10:40 PM
JRC2000SS's Avatar
i did a bleed on the master cylinder... and it worked. thanks fellas for the help. now i dont have to worry for awhile about gettin a new one. that will be in due time when i get my clutch.
