master and slave cylinder question
Old May 27, 2008 | 12:23 AM
WS7_FORMULA's Avatar
Exclamation master and slave cylinder question
whats the difference between this two?? How do I know which one is worn out/or which one to get new???
im about to have installed a fidanza flywheel and spec 2 clutch...so apparently i heard from car guys that i need to also change the cylinder....but which one really?? I need help big time. Can someone please help me, thanks!!
Old May 27, 2008 | 01:19 AM
will350wax's Avatar
master is up by your clutch pedal
Slave is in the bell housing of your transmission.
If you are going to pull the transmission to put in a new clutch, why not spend the 80 bucks for a new slave?
are you having any clutch problems?
Old May 27, 2008 | 08:37 AM
yea When I Would Put In The Clutch Pedal I Would Here Some Small Clacking Noises (throw Out Bearing). Then One Day I Stayed Stuck At Home...i Couldnt Get Gears In At All...so I Left It For 3 Days...and Then I Used It Again For Another 2 Weeks And It Workde Fine...then It Did The Same Thing Again So I Just Rest The Car...my Friends Said It Is The Clutch Pump...what Do U Think??? I Bought The Clutch And Flywheel, But Im Just Wondering Now, Cylinder Made The Car React Stuck....???
Old May 27, 2008 | 08:40 AM
also I Had To Refill My Clutch Fluid All The Time
Old May 27, 2008 | 08:59 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
If something is leaking, find out where it's leaking. . .replace that part. If you are already replacing the clutch, you need to change the slave cylinder/throwout bearing while you are in there regardless though, so you know you at least need to replace that one.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 27, 2008 | 09:34 AM
do i really have to replace it????
Old May 27, 2008 | 10:02 AM
The slave cylinder/throwout bearing assembly? Yes, it is highly recommended.
__________________
Old May 27, 2008 | 04:21 PM
thanks Man For The Help....my Pedal Feels Fine Ever Since I Got The Car...it Doesnt Get Stuck When My Car Broke...right Now I Can Move The Car And Shift Gears Easy, But The More Use It Gets Thats When The Gears Dont Go In...almost Like If That Cylinder Gave Out Its Potence....that Was One Of The Other Symptoms It Had.....but Right Now Im Not Using The Car Cuz Not Reliable To Use And I Need To Fix It Rather Than Continue Breaking It
