LT1 Mechanic
i figure a good mechanic can get it where it will benefit from a tune.
thx
charlie
thx
charlie
i re-stabbed the opti after the 1st time and it seemed to go back in easy too, so i dont know if i mess up the guide or something like that. it runs like its a tooth off too.
http://www.corvettefever.com/howto/16758/index.html
http://www.chevytalk.org/fusionbb/sh...hp?tid/189777/
And the list goes on and on about how moisture in the water pump due to washing the engine, seals going out on the water pump, or replacing the water pump will ruin an opti. The vented opti crap was the solution used marginally helped optis being ruined by moisture. Sorry to the OP about this thread turning into this, just didnt want the possibility excluded from things to check.
ive had vented and non vented both get water inside them...never once replaced an opti due to the opti actually failing...ive only owned about 5 of them over the past 5 years..and personally know another 3 that my buddys have had for 2 years or more...
they get water in them they just need to dry...ive even started a car with carb cleaner inside an opti and had it backfire inside it when it started and still runs till this day...
moisture in the opti only means you need to stick a fan under the hood and let it blow towards the opti for a few hours and it will dry out and be fine...ive got a solution to fix that...but its my little secret...i can use a pressure washer on my opti and have no problems now
i haven't figured out the starting issue yet. when i turn the key forward sometimes it will only spin over what seems like 1/2 a revolution and then i hear a clicking sound from under the dash. relay? if so where? the starter is new and tested out ok.
I think I'm doing it old shcool ... open the radiator cap and run it until the thermostat opens ... add water then put the cap on. what am i doing wrong ... keeps spitting water out of the radiator.
