Which NGK Plugs to run for N/A setup
Old Jun 2, 2008 | 12:19 PM
turbopaez's Avatar
Default Which NGK Plugs to run for N/A setup
Will it be the NGK TR555 or the NGK 6 and at what gap? Thanks
Old Jun 2, 2008 | 12:22 PM
Mr Powell's Avatar
NGK TR55, but I can't remember what gap exactly. I want to say 44, but don't quote me on that. It's been a VERY long time since I used a TR55, I'm use to running NGK 8's on my brothers n2o LS1
Old Jun 2, 2008 | 12:35 PM
1meantransam's Avatar
if your running anything over 400 horse you don't want to run TR5s, it's not going to hurt anything (usually) but after you hit that point you will want to run a higher plug. TR6 is safe.
Old Jun 2, 2008 | 12:36 PM
built408's Avatar
TR55 gapped to .035
Old Jun 2, 2008 | 04:24 PM
turbopaez's Avatar
So the tr55 will work fine up to 400? Can I just use the tr6 and at what gap?
Old Jun 2, 2008 | 04:41 PM
built408's Avatar
.035 which is what they are set at
Old Jun 2, 2008 | 08:19 PM
turbopaez's Avatar
I just pulled one of the plugs and they where Bosh Platium. Are those any good?
Old Jun 2, 2008 | 08:21 PM
dlt76028's Avatar
12 Second Truck Club
no...
Old Jun 2, 2008 | 10:07 PM
lol...no, there better for imports from what i understand. NGK is a good plug, Autolite isn't a bad plug either. cheap, i just stick with NGK for my cars.
Old Jun 2, 2008 | 10:17 PM
kornfreak_401's Avatar
NGK TR6 is bigger in what sense?
Old Jun 2, 2008 | 10:21 PM
turbopaez's Avatar
I picked up the tr5's since every thing I read and want people said to use the tr6 for spray...
Old Jun 2, 2008 | 10:42 PM
heat range. most cars in my range are fine with a tr55 because it doesn't have alot of power but when you get more power (heat) you want a cooler plug wich is a higher numbered plug for NGK. if you run to hot of a plug with to hot of an engine your running the risk of burring a hole in the piston, and "you're a dumbass if you run something like that" (some people will know who says this
Old Jun 3, 2008 | 09:30 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
TR55 is what I would run in your car.
Coach
Old Jun 3, 2008 | 09:37 AM
turbopaez's Avatar
Thanks guys for all your help. I ended up picking up the tr55.
