Help, 01 Camaro LS1
Old Jul 3, 2008 | 09:54 PM
Dirty 30's Avatar
Default Help, 01 Camaro LS1
So after doing an LS1 swap in my cousins camaro, the car has been acting up since. I went to autozone and they told me it was the O2 sensors but I already put brand new ones (13111-Vette O2's). The car has been tuned for mild cam and stall. The car sputters when i turn it on and stalls out sometimes. Once it warms up and while driving, it acts better. When you get to the light it turns off again though. I already fixed the fuel problem so i know its not that. I checked the fuses and the O2 sensors for burn marks but I dont see anything.
Can anyone help me out here, individual or shop. Im located in 75217 near Balch Springs but can travel. Prefferably someone with a scanner or hptuners and with knowledge on these matters. I can come up with some cash.
Thanks in advance!
-Jesse
Old Jul 3, 2008 | 09:55 PM
Sarge_13's Avatar
I know you said you checked it but are you positive the plugs/wires are good?
Old Jul 3, 2008 | 09:57 PM
PatriotT/A's Avatar
Still sounds like a tune problem to me, but your first big mistake is consulting Auto Zone.
Old Jul 3, 2008 | 09:59 PM
Dirty 30's Avatar
LOL i know, my scanner cable doesnt work so i had no choice
Dirty 30's Avatar
By plugs and wires u mean 'spark' plugs and wires? If so, then no i havent checked them.
Old Jul 3, 2008 | 10:00 PM
Sarge_13's Avatar
One of my friends had a couple bad spark plugs and caused similar symptoms that you're describing.
Old Jul 3, 2008 | 10:02 PM
Dirty 30's Avatar
I think i should check them. Im just tired of this freaking car. I feel like doing the LS1 swap wasnt worth it. :sigh:
Old Jul 4, 2008 | 01:47 AM
chrysler kid's Avatar
check to make sure the intake manifold is tightened down to spec, there is a diagram to follow to tighten them in a specific order
Old Jul 4, 2008 | 10:52 AM
Dirty 30's Avatar
I definatly need to check those two things out then. Thanks! I'll post up after I do...
Old Jul 4, 2008 | 11:08 AM
Mike96z's Avatar
I told you MAF sensor.
Old Jul 4, 2008 | 11:09 AM
Mike96z's Avatar
Hey if you can get it here Ill put mine on your car and see if it helps.
Old Jul 4, 2008 | 11:16 AM
Dirty 30's Avatar
i already tried another MAFS and it didnt work, but that problem was the fuel pump. I fixed that problem already tho.
