Need Help! Massive Misfires on New Motor
OK, I'm about ready to shoot this thing! I need some help trying to tackle a massive misfire problem under a load. Here's the rundown: 2001 Trans Am. Original motor exploded due to valve spring failure. Replaced with a 2004 LS6 block, LS6 heads (milled .020), Mahle forged -6cc pistons, SCAT H-Beam rods, SCAT 4" crank, Comp Cam 224/230, .610/.605" 114 LSA cam, stock intake and injectors. G-Force loaded tune, but didn't help.
I am getting P0300 and flashing SES light. I know this means a misfire and fuel dumping into cats.
The question is why. Plugs (NGK TR55's) were black on passenger bank, fairly normal on driver's bank. So, I replaced O2 sensor on the passenger bank this morning - no changes. Previously have switched coil banks, put stock wires back on, put new plugs in (NGK TR55 platinum), still no change.
Read about crank relearn. Possible problem with the crank crankshaft? G-Force said that it would have throw a code if the crank needed a relearn. True? Another thread mentioned crank position sensor. Can engine still runs with a bad one? How about the cam position sensor?
Also, did a compression check yesterday. Results: cylinders 1, 3, 5, & 7 all had around 210 pounds. Cylinders 2 &4 - 200lbs, 6 - 195lbs, 8 - 180lbs. Now, would cylinders 6 & 8 be bad enough to cause a misfire?
Please help! Can't figure this out! If anyone local has a Tech II or other scanning tool, I would be greatful for some help! Thanks!
Brian
Brian
Weird man I had the ame issue but it was my crank sensor. I had a burnt wire on it sometimes it works and somtimes it dident . I have since replace the sensor and wire. Oh check the water temp unit on the driver side head make sure it works. I wold have the car running and have somebody wiggle it to see. I had this happen to me befor and the car would just dump fuel an temp guage would go to zero.
Here's the latest: I pulled the valve covers and noticed that all the valves are in the closed position. Only a few look like that have any pressure from the cam/lifters/rocker arm. When cranking over, they seem to pump up, but immediately collapse - like within 2-4 seconds to the closed valve. Should the lifters bleed down that quickly? Could this be my problem? Does it sound feasible that the valves just aren't opening enough and this is causing the misfire? I'm about ready to pull the heads and replace the lifters. Please advise!! Thanks!!
I guess I'm mainly concerned about the lifters bleeding down that fast. Should that happen? Or should they stay solid longer (do I need to drop a few Viagra's in the oil filler?!?!) I mean, I have pulled valve covers off my Pontiac 455 and the valves are compressed on the lobes showing lift. Shouldn't the LS1 act accordingly?
OK, replaced crank position sensor - no change. I went to G-Force this morning. Mike did the crank re-learn - no change. Swapped a coil pack on the passenger side - no change. The passenger bank is clearly the side that's having a problem. All the plugs are showing black on the passenger side, normal on the driver's side. So, I tried changing the O2 sensor - still no change. So, what else can it be? I'm down to:
Bad PCM?
Bad Lifters?
Dead cylinder?
PCM: Anyway to test if it's bad?
Lifters: I can change, but would they be bad enough to cause the problems?
Dead cylinder: Did a compression check on all cylinders. Driver's bank - all 210 pounds. Passenger bank: 2 &4: 200 pounds, 6: 195 pounds, 8: 180 pounds. OK, 6 & 8 are low, but are they low enough to cause a massive misfire? How can I test??
Need help!!!!
Bad PCM?
Bad Lifters?
Dead cylinder?
Need help!!!!
Have you checked the ignition fuses? Is the pass side banks fireing at all? I have ran across it ONCE, there was no power going to main coil plug that fires all of the coils. Dont know why it popped the fuse but all was good after, the whole drivers side bank was dead.
On my old GMC Sierra, I had that same problem. Misfires in 6 and 8 on the passenger side. Turned out to be that little fuel pressure regulator on the fuel rail going from the drivers side to the passenger side fuel rail was bad, causing it do dump too much fuel in on the passengers side. Replaced it, and the problem was solved (got better gas mileage too, heh). My f-body has aftermarket rails on, so I don't remember if the stock fuel rails have that regulator?
Well, I finally found out what the problem was: plugged catalytic converter on the passenger side. I pulled the Y-pipe off, fired the car up and there was no flow at all. Remove the cat, gutted the interior, re-installed and fired it up again. Success!!
This was without-a-doubt, the most frustrating problem I've ever had with a car!! I'm just glad I finally could figure it out!!
