HPE Heads/Cam special
Well after taking the vote a few days ago, it was clear that most people would like a special on doing a heads/cam setup to their car. So here's the deal...
Every package is going to have these base components.
HPE cam of your choice (specs available listed below)
Trick Flow hardened pushrods
GM MLS Head Gaskets
GM Head Bolts
NGK TR6 spark plugs
Oil and filter
Installation
Dyno tune
Base components package 2026.56
Next we will offer 3 choices in cylinder heads. You can chose what you want, just add the price listed (which includes tax), to the base components package price listed above.
HPE Stage 2 LS6 cnc'd cylinder heads: 1407.
New GM 243 casting
5 axis CNC machined
220cc Intake Runner
Intake Flow Rate 305 CFM
Exhaust Flow Rate 235 CFM
New 2.000 intake valves / 1.550 exhaust valves
GM valve seals
Super 7 locks
Livernois dual coil valve springs good to 690 lift
Livernois titanium retainers
No core required
Dart Pro 1 Cylinder heads: 1731.
*Available in 2 different sizes, call for more information.
Trick Flow CNC'd cylinder heads: 3040.
*Price includes upgraded Yella Terra ultra light weight rocker arms
Package options and upgrades.
GM LS7 Lifters: +148.24
GM LS3 oil pump: +135.31
N-Motion double roller timing chain: +162.32
Ported Throttle Body: +100.00
ASP Underdrive pulley w/ belts:+297.68
SVO 30# injectors: +259.80
ARP Head Bolts: +103.29
HPE Cam List
Comp Cam- 224/230 on a 112 LSA 581/592 lift
C cam- 232/234 on a 112 LSA 595/598 lift
C+ cam- 236/238 on a 112 LSA 602/605 lift
S cam- 238/240 on a 112 LSA 605/609 lift
S+ cam- 238/242 on a 113 LSA 605/610 lift
S2 cam- 239/242 on a 112 LSA 651/610 lift (kit is 50 dollars more than the rest due to Patriot Extreme springs instead of Manley's)
Blower grind- 235/242 on a 115 LSA 648/610 lift (kit is 50 dollars more than the rest due to Patriot Extreme springs instead of Manley's)
Mega Death cam- 244/242 on a 112 LSA 612/610 lift
PRICES ALREADY INCLUDE TAX
For more details contact me or call the shop.
GM MLS Head Gaskets
GM Head Bolts
NGK TR6 spark plugs
Oil and filter
Installation
Dyno tune
New GM 243 casting
5 axis CNC machined
220cc Intake Runner
GM valve seals
Super 7 locks
No core required
HPE Cam List
