Low Oil Pressure
Old Sep 22, 2008 | 10:42 PM
Fara04's Avatar
Default Low Oil Pressure
Ok guys I recently had Damaged my head valves on a bad timing on the chain, well I put another set of 317's put some new lifters and a ls2 timing chain, I turned the truck on and everything looks to be fine engine doesnt shake or anything no noise but my oil pressure is slow like at around 30, the only different thing I did was that I took my 3200 converter off and put my original back on.... could the low oil pressure be because of the original converter in other words the "Tune" and I also forgot to mention I have a ported oil pump that I bought a month ago!!!!! and this is on a LQ4
Old Sep 22, 2008 | 11:16 PM
Fara04's Avatar
to the top
Old Sep 23, 2008 | 01:27 AM
beedo's Avatar
wanna sell the verter?
Old Sep 23, 2008 | 12:43 PM
Fara04's Avatar
I already did bro
Old Sep 23, 2008 | 09:30 PM
Fara04's Avatar
ttt....
Old Sep 23, 2008 | 10:07 PM
Greed4Speed's Avatar
Didn't touch the oil pump?
Old Sep 24, 2008 | 01:27 AM
Fara04's Avatar
when I put the ls2 timing chain I did, because befor at WOT it would go all the way to 80 and now it only goes up to 45 or 50 , can I mess something up if I keep driving it like that???
Old Sep 24, 2008 | 08:05 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Did you use a blue or green oil pump pickup tube o-ring? Trucks usually use the thicker green o-ring.
Old Sep 24, 2008 | 08:47 AM
Or the O-ring could have a small pinch.
Old Sep 24, 2008 | 09:48 AM
xfactor_pitbulls's Avatar
I second that. Its pretty common to not have them seat right and pinch one side, then bleed the other. Check your O-ring.
Old Sep 24, 2008 | 06:08 PM
What a Rush's Avatar
From: Putting my feet in your couch, cause thats how im living
The O ring was the issue with my car having hardly any pressure. I third that motion.
Zach
Old Sep 24, 2008 | 08:02 PM
beedo's Avatar
Make sure the oil sender is good, sometimes when you pull the trans the sender will hit the firewall or get pulled with some wires and break. If your local I have a manual gauge and an adapter that screws onto the oil filter adapter. DFW
