Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Which OBDII Diagnostic tool?
Old Oct 11, 2008 | 12:31 PM
meangreenformula's Avatar
Default Which OBDII Diagnostic tool?
Hello,
I have been looking around for a diagnostic scanner. I have a 97 so it will need to be able to read OBDII. I am looking for something that will mainly scan trouble codes and such. I found this craftsman for $100, which is pretty much the most I will want to spend. Is this a good scanner or are there others that are better and will do more?
Thanks for any input.
Old Oct 11, 2008 | 11:11 PM
01ssreda4's Avatar
i have used the harbor freight one and it works fine. catch it on sale.
Old Oct 12, 2008 | 07:14 PM
RitcheyRch's Avatar
I have the Autoxray 6000.
Old Oct 12, 2008 | 11:14 PM
00pooterSS's Avatar
pretty much all the readers are the same, they can be found for like 60-70$ now and those would be fine, some have a couple more display features but thats it, remember these dont diagnose anything they are just code readers, will only give you the code, which if you are aware of that then that is fine.
Old Oct 21, 2008 | 04:49 PM
ramairracer's Avatar
gm tech 2, (i have one) top of the line!
Old Oct 21, 2008 | 05:48 PM
MadIceV8's Avatar
Customizing Director
I have a Actron CP9175, works great. Displays the code and tells you what it means on the display. Some of the cheaper ones just display the code and you have to look it up in a book or online.
These are more of a convenience item since you can get codes read for free at autozone or jiffy lube.
Old Nov 6, 2008 | 04:30 PM
99SSRhodes's Avatar
Tech 2s are awesome thats what we use at the dealership and at school but i dont think hes looking for something of that level lol
Old Nov 6, 2008 | 05:37 PM
Darksol's Avatar
Thought he said he only wanted to spend $100 not thousands.
Old Nov 8, 2008 | 04:12 PM
koolaid_kid's Avatar
I would get something like this:
http://www.harborfreight.com/cpi/cta...emnumber=94217
IMHO, what you want is a scanner that will also clear the codes for you. I use Autotap, which is a lot more expensive, but the ability to clear the codes is "priceless".
If you can read the code, you can look it up on the web on sites such as:
http://www.obd-codes.com/trouble_codes/
There are many sites, you just have to Google.
