Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
compressor surging
Old Nov 23, 2008 | 09:25 AM
MUSTANGBRKR02's Avatar
Question compressor surging
I bought a used compressor a month ago or so and after a few times using it the compressor is now surging and will not build past 50 psi. Is it time for a new motor? Its a 230v 5hp 60 gallon single stage.
Old Nov 23, 2008 | 12:47 PM
MikeGyver's Avatar
I've seen belts slipping and not squealing.
Old Nov 23, 2008 | 01:10 PM
the actual motor is surging though not belt slipping.
Old Nov 23, 2008 | 01:36 PM
think i figured it out. I believe that i burnt up my breaker so i am going to try to change that.
Old Nov 23, 2008 | 09:48 PM
Gordon0652's Avatar
Warranty...?
Old Nov 24, 2008 | 04:03 AM
the breaker crapped out it is all better now
Old Nov 24, 2008 | 06:57 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Since the breaker crapped out, I'm guessing you weren't getting a full 240v at the compressor motor. Probably why it would only go to 50psi.
Old Nov 24, 2008 | 10:15 AM
Old Geezer's Avatar
If the breaker U R referring to, is in the panel.. there's another problem. Something is causing excessively hi amp draws, above the breaker rating....IE: Start capacitor fubar, on the motor??
Start up amp draws can be up to 6x running amps.
