Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
rivet question
Old Nov 24, 2008 | 04:54 PM
WMSuperSport's Avatar
Default rivet question
Sometimes the long part of the rivet that goes into the gun snaps in the gun, leaving the long shaft coming from the rivet head. Is this a rivet, gun, or technique issue? thanks
Old Nov 24, 2008 | 05:38 PM
flirtnwithdisaster's Avatar
Big daddy rivets have several types. most snap and leave 1/4 sticking out
Old Nov 24, 2008 | 06:51 PM
MUSTANGBRKR02's Avatar
This could be any of the three. Just make sure you are on there straight, you apply some force and you are not resting your finger on the trigger.
Old Nov 25, 2008 | 09:09 AM
you definitely have to use force to squeeze the handle together. how are you shaving down the part sticking out, thats normally broke off? i thought about a die grinder?
Old Nov 26, 2008 | 01:04 PM
jimmyblue's Avatar
Moderator
Use a pin punch and push the "nail" clean out?
Old Nov 27, 2008 | 10:49 AM
thanks, jimmy. it worked on 4 out of 5. the last one i carefully ground down. thanks for the idea
Old Nov 27, 2008 | 12:39 PM
jmd's Avatar
jmd
My gun has two lever arms and looks something like this:
With adjustment of the parts assembly (see jam nut, main bore and the installed tip,) the nail will drop right out of it. Your gun may be different but check it out.
Old Nov 27, 2008 | 03:21 PM
i was using a super cheap one, but i bought a cheap home depot one that works perfect. ill have to check that gun out
