Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Its time to build my garage need input on sizing
Old 12-29-2008, 07:43 PM
Shawn @ VA Speed's Avatar
Originally Posted by Phil99vette
Man, I've got a nice sized master bedroom/Bathroom competely furnished with a big screen and internet access setup for you and Angie. Studs are up, we're running the electric this week, plumber was in last week finished the rough in for the bathroom, insulation and drywall will be next week.
The shop will have a seperate engine room for assembly and seperate bay for the your camaro. Not many people get your type of treatment.
That's what i'm talking about-how about a brass pole?
Old 12-29-2008, 08:31 PM
Originally Posted by BlueMonza
Can't have a brass pole without a stocked bar!!!
why didnt think of that.I guess we'll need a big *** stereo and some mirrors on the walls and ceiling
Old 12-30-2008, 02:55 PM
7 Second Club
Phil99vette's Avatar
One section will have a Bar with 5-7 stools, pool table, couple flat screen TVs and a pole in the corner with a lounge area.
Old 12-30-2008, 04:05 PM
7 Second Club
Umm who was kidding? Thanks man, with our engine troubles behind us its time to kick some ***.
Old 12-30-2008, 08:53 PM
That **** is better than my house
Old 01-21-2009, 03:39 PM
SSJIMMY's Avatar
I ended up ordering a 40x50 Steel Building package. Should be here in a couple weeks. I've got a local engineer that is going to work on the foundation drawings. I think it will be big enough for what I am doing. Thanks guys.
That should be a good size for what your doing. where did you order it from?
Old 01-21-2009, 03:44 PM
7 Second Club
Olympia steel buildings. So far we have the site work done, the plans are at the architect getting the engineered foundation drawings prepared. The building should be here in a couple weeks.
Old 01-22-2009, 05:39 PM
SevenStars's Avatar
Thanks for the tip. How much do you know about the waste oil burners and the glycol system?
I dont know a hell of alot about the workings of a glycol system as I still havent gotten to insulating my shop or hooking up a hot water heater.
What I did when my shop was built is I bought the infloor tubing and insulated/ ran everything before I poured my floor then I made a system to pressurize the tubing for when it was poured. I did all the work my self and it was easy, just a bit time consuming.
All in all it was only a couple of hundred extra dollars and IMO its worth it because you always can go another route after you pour but you cant ever add the tubes later.
If you do go this route let me know. I have most of the special tools needed, the tie downs and alot of extra lines new in the box. There just sitting here taking up space..
One place that is filled with great ideas and covers anything you'd want to know is garagejournal.com
Old 01-23-2009, 08:45 AM
bgblockelcamino's Avatar
if you can def consider the heated floors. your body will thank yourself when it is cold outside. i wish i could have done it but was running low on funds at the time. they have waste oil boilers too so you can have free heat too.
good luck with build.
Old 01-23-2009, 08:56 AM
dondb's Avatar
Bigger is Better For 2500 more, absolutley!!!
Old 01-24-2009, 09:02 AM
DAVID@VASPEED's Avatar
If there's a brass pole I want in too, **** I'll sleep on the floor in the shop.
Old 01-24-2009, 07:28 PM
  #32
brent5631's Avatar
If your not aware of this place you should have a look around. there are some nice shops and good advice.
http://www.garagejournal.com/forum/
Old 01-24-2009, 07:58 PM
  #33
7 Second Club
Thanks man, I'll check it out.
Old 02-01-2009, 10:16 AM
  #34
Moderator
davered00ss's Avatar
Gotta have heat. My cold *** 24 X 24 sucks. A friend just did a 30 X40 with a lift. He needs heat now though.
Old 02-08-2009, 07:09 PM
  #35
7 Second Club
Just an update. We got the house sheet-rocked and we starting painting. The site work on the garage has been done, plans are going to the county for a permit for the foundation. As soon as we get the permit we'll have our buddy take care of the slab/foundation. The building should be here in the next 14 days. I need to get the house 90% done before I break away and start the garage.
Old 02-08-2009, 09:03 PM
  #36
SSJIMMY's Avatar
Good luck man if your doing it by yourself it will take some time just hang in there and hope your wife doesnt get mad at you if the house is not done and your working on the shop.
Old 02-09-2009, 06:42 PM
  #37
7 Second Club
Well good news is I have some help. My dad, uncle, next door neighbor and wife have been a big help in getting our new house completed. I would have never thought that you could save this much money on a house by doing it yourself and shopping subs.
Old 02-22-2009, 07:00 PM
  #38
7 Second Club
Garage is getting delivered wednesday, hopefully I'll have some pics before the concrete work starts. Heading over on thursday to get the permit.
Old 03-30-2009, 09:19 PM
  #39
7 Second Club
Couple pics on the progress on the soon to be garage. Concrete man said it should be done this week weather permitting. Shop will end up 40 x 50.
Attached Thumbnails Its time to build my garage need input on sizing-img_02426.jpg   Its time to build my garage need input on sizing-img_02438.jpg   Its time to build my garage need input on sizing-img_02425.jpg
Old 04-06-2009, 09:40 AM
  #40
BusDriver's Avatar
Are you putting in the radiant floor tubing? Nothing is more efficient or cozy than a toasty warm floor. And, anything you can think of to warm up water can be used to heat. From waste oil burners to a passive solar collector, lots of DIY and/or cheap ways to end up warm.
You can't retrofit this, gotta put the tube in the concrete to make it work. Even if you heat the garage, the floor will be COLD in the winter, and you lie on the garage floor a lot.
Quick Reply: Its time to build my garage need input on sizing
