Lets talk garage lighting...
I do have door openers, they are a "high lift" kit, as the ceiling is 12' 4" but the bay doors are only 8' tall. The tracks run up high, and are operated by Liftmaster jackshaft units. This keeps the openers from hanging down in the middle of the shop (wouldn't work where the lift is, at least when my van or an SUV is on it, plus you can't really do that with a high lift kit anyway, as the geometry doesn't work).
Cobra, just keep in mind as you wire these pull about 2 amps per fixture, so just be mindful of that as you run them (together) on existing wiring (12 ga or 14 ga, 15a or 20a switches, breakers, etc)
Congrats on the new house, my Fiance and I are currently searching for a new place and would love new construction but that doesn't look likely with NJ real estate prices.
If you have 14 ga wire on 15 amp switches/breakers, just don't put but maybe 7 max on that circuit, assuming nothing else is on that circuit.
I work with one four-foot floresent two-bulb fixture and one light bulb on the side.
Special projects get a trouble light on a cord.
My next garage is going to have high ceilings and a lift.
How do you guys keep the bugs out with all those lights working like a magnet?
http://www.greenelectricalsupply.com...day-light.aspx
I find that's plenty of light while working in the garage.
A 4' 2 bulb fixture is all you really need if you have a ceiling height less then 15' I sell them for $94. I could make a LS1tech price though hit me up and I would gladly cut you guys a deal.
Just be careful about how much you advertize on here. The sponsor natzi's don't like it and will want you to pay the sponsor fees for helping out people on here. Just FYI.
Thanks for the information Chad, very helpful
I agree with you. I don't think it should be an issue with someone helping out with garage lighting, but everytime I've seen someone offer anything for sale, mods jump in and shut it down and edit any contact info.
I'm just saying, keep things to PM's and you should be fine.
I agree 100%.. I was reading this post with people sayin t12's are better and smaller, and was like what. I am a commercial/industrial electrician. I do lighting in offices/factories all the time.
I Agree t5 is where its at, but t5's are better up higher. We are using t5 as the hi bay replacements, instead of the 400 w metal halides.
The t8's are going to be the best way to go for a garage, and definatly the best price.
Just so you know the numbers are in 1/8th of a inch. So a t12 bulb is 1.5 inches, a t8 is 1 inch, and a t5 is 5/8's.
Another huge part of these fixtures is the reflector...
good luck, and if you have any electrical/wiring questions let me know.
Chris
The thing is that they use the same sockets so they're physically interchangeable, but almost all the efficiency difference is not from the different lightbulb but from the electronic ballast design used with the T8 vs the magnetic ballast used by the T12. As long as there is room between the reflector and the fixture, you can stick T12's in a T8 fixture and get most of the advantages, but not vice versa.
The high output and the cold weather setups are the same thing, they're just a higher output bulb that works better below 32*.
