Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
ls1 onto engine stand Q's?
Old Dec 30, 2008 | 07:52 PM
05chevyguy's Avatar
Default ls1 onto engine stand Q's?
ok guys this is my first time mounting an engine to a stand.... i have an 02 ls1 and an Ac Delco engine stand i just got from a friend... what kind of bolts do i need to make this work? and how do i do it?
thanks in advance.
Preston
Old Dec 30, 2008 | 09:00 PM
05chevyguy's Avatar
no one?
Old Dec 31, 2008 | 02:22 AM
TX RED's Avatar
pull one of you bell houseing bolts take it to local hardware store. Get it about 3 in long make sure its a grade 8 bolt, and it going to be metric hope that helps
Old Dec 31, 2008 | 11:59 AM
mondols1's Avatar
i cant remember the sponsor but there is one who sells a bolt set for this and they are arp qualty type bolts, call tx speed, thunder etc... try a search someone was talking about this recently.
Old Dec 31, 2008 | 12:15 PM
Camaroholic's Avatar
Long M10x1.5 bolts will do the trick. I just went to the hardware store and picked some up. No problems at all, no need to spend a ridiculous amount on bolts.
I use AC Delco stands as well, but I forget how long my bolts were. 5" or thereabouts. It's easier to buy "too long" and shim (using washers, big nuts, whatever), than it is to buy "too short" and be out some threads.
Old Dec 31, 2008 | 12:38 PM
05chevyguy's Avatar
lol thanks guys this helps alot!
Old Jan 1, 2009 | 10:20 AM
Damian's Avatar
LSX Mechanic
Starter bolts work great. I have a few of them saved up over the years. I use a lug nut on each one to act like a "washer" to keep the bolt from bottoming out in the block before getting tight, works good.
Old Jan 3, 2009 | 10:19 AM
Danno74Z's Avatar
Default Engine stand question.
When mounting the LS1 engine to an engine stand do I have to remove the entire transmission (T56) from the engine? Meaning, can I leave the bell housing attached to the block and just attach the stand to where the transmission bolts up to the bell housing? I would like to leave the bell housing, flywheel and PP in place for now. I don't want to damage anything by supporting the engine this way. I hope this is not too stupid a question!
Dann74Z
Old Nov 21, 2010 | 12:50 PM
mdpalmer's Avatar
Question
Dann74Z
^^ I would like to know too. Would rather not have to remove clutch disc/PP...
Old Nov 21, 2010 | 02:31 PM
01ssreda4's Avatar
I would remove the bellhousing yes. If not you are pushing the weight of the engine further away from the stand, possibly throwing the stand off balance, and over-stressing the bolts causing a possible bolt failure. Too much to risk IMO.
Old Nov 21, 2010 | 05:02 PM
MrElectric03's Avatar
Absolutely remove the bell housing. I dont think its strong enough to support the entire weight of the engine. Depending on the stand you may be able to get away with leaving the clutch setup on but if not remove it. The last thing you want is replacing the oil pan and whatever else breaks(or whoever is falls on) because you didnt wanna remove a few bolts.
