Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
anyone with a 2 post frame lift inside
Old Feb 8, 2009 | 07:43 PM
blackbyrd's Avatar
Default anyone with a 2 post frame lift inside
so im using my lift today everything is fine and all of the sudden it starts humming when its going up and moves very slow, guess its time to grease the slides but whats good to use?? litium grease, wd40, all suggestions welcome
Old Feb 8, 2009 | 07:49 PM
Gordon0652's Avatar
Do you have ball bearing wheels? Or pieces of plastic that slide?
Old Feb 8, 2009 | 08:29 PM
bgblockelcamino's Avatar
lithium grease
Old Feb 8, 2009 | 08:36 PM
76LS1BIRD's Avatar
Restricted User
Make sure the hyd. fluid is full.
Dale
Old Feb 8, 2009 | 09:23 PM
blackbyrd's Avatar
hyd. fluid is full and it has the white plastic inside.
Old Feb 8, 2009 | 10:00 PM
Gordon0652's Avatar
i use WD40, then wipe it off a few minutes later but mine had bearings, not the sliding plastic, maybe its time to replace that plastic?
Old Feb 17, 2009 | 10:04 PM
Irocss85's Avatar
lithium grease here too. havent had to redo mine yet been a few years and still good. but I put a bunch in there with the hoist lowered and raised so it would coat the slides really well.
Old Feb 18, 2009 | 01:57 PM
mitchntx's Avatar
Motorcycle chain lube is what I use. It's parafin based and sticks where you spray it.
