Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
What Jack Are You Using
Old Feb 9, 2009 | 01:35 PM
TORCHD 02 TA's Avatar
Default What Jack Are You Using
i figured this topic would get more action here. But Russ or anyone else who thinks this should be moved then go ahead..
But what jack are you all using? Where is a good place to buy one?
Old Feb 9, 2009 | 02:53 PM
Magnet's Avatar
I would like to know too... mine always crap out so I'm stuck with either a broke one or little crappy ones.. maybe I'm just cheap... I want to get a good one and never worry about it again..
Old Feb 9, 2009 | 03:06 PM
MeentSS02's Avatar
Kleeborp the Moderator™
There is a Tools & Fabrication section you know...if you'd search you'll find that it has been discussed in there multiple times.
<------------ AC Hydraulics DK-13HLQ for this guy.
Old Feb 9, 2009 | 03:15 PM
i had no idea there was section called that. I pretty much stay in the appearance section, Internal/External, midwest, classifieds and thats about it
Old Feb 9, 2009 | 03:19 PM
98 WS6's Avatar
I've had a Craftsman jack since I was 13 when I had my Camaro.
http://www.sears.com/shc/s/p_10153_12605_00950140000P
It's nothing fancy but it does the job. Sometimes I have trouble getting it under my T/A though, but I've always seemed to make it work
Old Feb 9, 2009 | 03:23 PM
Tricked-Out-Toy's Avatar
Direct lift 8000, it works pretty well
Old Feb 9, 2009 | 03:25 PM
MeentSS02's Avatar
You should check it out from time to time - lots of great tool discussion, ideas, etc. for how to do projects. A thread in there is what steered me towards the AC Hydraulic Jack - it is a pricey SOB, but I'll be damned if it hasn't been the biggest time saver of any tool in my garage. I can reach (at an angle of course) the k-member with the car sitting on the ground (and my car is lowered ~1.5"), and I can go right around to the back and reach the pumpkin on the rear to jack the back end up. No more of this side-to-side jacking bullshit I had to do with my POS Jeg's aluminum jack.
Old Feb 9, 2009 | 03:47 PM
i wish i had that option
Old Feb 9, 2009 | 03:48 PM
Brian on that Craftsmen jack, i do not like how the contact point is soooo tiny. I like the contact point to be bigger than that. that is JMO
Old Feb 9, 2009 | 04:31 PM
98 WS6's Avatar
No hard feelings, I didn't make the jack! I agree though, I usually constantly check where the plate is while I'm jacking it up, just to be sure cause the damn thing is tiny
Old Feb 9, 2009 | 05:17 PM
Spd-Kilz's Avatar
Just some old one that's been in the garage forever. I should really get a low profile one.
Does anyone here use rhino ramps?
Old Feb 15, 2009 | 10:49 AM
Jeff Smith's Avatar
^^^^Recently, I bought Arcan XL35 (#144236) 3-1/2 ton and can liftup ~20" & 1 yr warranty thru NorthernTool.com. It costs me 149.99 plus s/h $59 to my "business garage"= ~ $227.
I had been researched on floor jack thru few forums/consumer reports/others. I hope so, I made choose the best jack lif-up>> Arcan XL35.
I copied from Northern Tool.com:::::
http://www.northerntool.com/webapp/w...5429_200345429
8 out of 8 would recommend to buy......
