Recommend me an air compressor
Thanks
Maybe their Compressors are different.
I was looking at this one. http://www.homedepot.com/webapp/wcs/...3+90401+524403
I've always heard that Husky makes very good Air Compressors.
My brother has a Husky air compressor that works great also.
A 20 gal compressor isn't going to store enough air to run say an angle grinder for a long enough period.
Look for CFM delivery at 90 psi.
Buy the biggest output your budget allows. If the output is enough, you do not need a large tank for home use.
Is 240 volt power available? If so go with a 240 volt unit
check this out.....
how about over 12 cfm at 90 psi and a 60 gallon tank for about the same price....
http://www.harborfreight.com/cpi/cta...emnumber=55222
or this, over 11 cfm at 90 psi with a 60 gallon tank.....
http://www.harborfreight.com/cpi/cta...emnumber=34887
i've also heard bad things about the IR 60 gal (the cheaper 3 hp model, not the 5 hp or t30 unit).
i have heard good things about the CH 60 gal units when you go with the heavy duty and their extreme duty models. they are just a little more expensive than the cheap blue one you see at lowes but seem to be made to a little better standard.
check out tractor supply for a deal on the ch heavy duty, look for a coupon. they will ship it to the closest store near you at no cost.
if i had more space and 3 phase electrical available i could have picked up many larger commercial units at great deals from cl but on these cheaper lighter duty 60 gal models all the ones i see on cl are being offered at to small of a discount from their orig price.
But we'd never use it for a big project like sanding and entire car or something.
http://steveswholesaletools.com/cata...887861935dfc50
