Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
How to use Front/rear Alignment Cover
Old Jul 6, 2009 | 09:00 AM
Big_Bird_WS6's Avatar
Default How to use Front/rear Alignment Cover
finally got to use my cover i made over the week end. so i thought i would right how to do it.
(mod, i dont know how to post full size pictures with text inbetween them. sorry)
Step 1.
clean off the front of block where cover sits. and the bottom of block where pan bolts down to.
Attached Thumbnails How to use Front/rear Alignment Cover-step-1.-clean.jpg
Old Jul 6, 2009 | 09:01 AM
Step 2
Start cover bolts and push cover back against block
Attached Thumbnails How to use Front/rear Alignment Cover-step-2.-start-cover-bolts.jpg
Old Jul 6, 2009 | 09:02 AM
Step 3
Start alignment bolts in block where pan bolts down
Attached Thumbnails How to use Front/rear Alignment Cover-step-3.-start-pan-bolts.jpg
Old Jul 6, 2009 | 09:03 AM
Step 4
Align cover bolts with alignment tool
Attached Thumbnails How to use Front/rear Alignment Cover-step-4.-alig-pan-cover-bolts.jpg
Old Jul 6, 2009 | 09:04 AM
Step 5
Torque block pan bolts to 18ft/lbs
Attached Thumbnails How to use Front/rear Alignment Cover-step-5.-torque-block-pan-bolts-18-ft-lb.jpg
Old Jul 6, 2009 | 09:06 AM
Step 6
Snug the cover alignment bolt. Tight but not to tight. they need to beable to slide a little
Attached Thumbnails How to use Front/rear Alignment Cover-step-6.-snug-pan-cover-bolts.jpg
Old Jul 6, 2009 | 09:08 AM
Step 7
tighten up all cover bolts. then Torque down the cover bolts to 18ft/lb
Attached Thumbnails How to use Front/rear Alignment Cover-step-7.-torque-cover-bolts-18-ft-lb.jpg
Old Jul 6, 2009 | 09:09 AM
Step 8
Remove the alignment bolts.
And there you go front cover is on.
Attached Thumbnails How to use Front/rear Alignment Cover-step-8.-remove-alignment-bolts.jpg
Old Jul 6, 2009 | 09:11 AM
Rear Cover
rear cover is the same as the front. but the two little bolts snug them. and when the pan goes on. they are only 106 in/lbs
Attached Thumbnails How to use Front/rear Alignment Cover-step-9-rear-cover.-106-lb.jpg
Old Jul 10, 2009 | 02:26 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm going to save this link as I have one of those tools currently sitting about 10 feet from me.
Old Jul 10, 2009 | 08:52 PM
mknight759's Avatar
were is the best place to buy a cover tool
Old Jul 12, 2009 | 01:20 PM
^^^ me
