anyone have a pinion depth checker around fort myers fl, i can borrow or rent
i put in some 4.11's and they are a little noisy , the only thing im not positive about is the pinion depth and i have no way to check it, i would really appreciate somone helping me out
i know the gear needs to come out further or add more shim but i dont want to do it 3 times , you have to pull that bearing and press it back on which i dont think i can do without screwing the bearing up, so i would like to check the depth before i pull the pinion, the gears were marked with what it should be , then ill know how much shim to add and get it spot on , i can live with how it is now , but i would prefer to fix it, if i go threw the trouble of reseting the pinion depth im going to make sure its perfect
