Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
worst fabrication EVER
Old Nov 16, 2009 | 02:22 PM
  #61
omarrakeen's Avatar
just check the comments they are all excited wanna see the HP gain
Old Nov 17, 2009 | 11:21 AM
  #62
BlwnLs1GTO's Avatar
I needed a good laugh. Thanks for that lol.
Old Nov 17, 2009 | 08:53 PM
  #63
livefast1's Avatar
the coulple of pics on that jalopnik website or whatever of the turbos mounted to the mufflers and then mounted under the rear seat are actually a very well fabricated build. he even went as far as making the sidescoops functional as the intake for each turbo and made a custom set of aluminum side skirts as charge pipes. it was a very tasteful and creative build but i believe the builder fell very ill/ had to get major surgery or something. wish people didn't put his stuff out there like that.
Old Nov 17, 2009 | 11:50 PM
  #64
94LTZ's Avatar
I saw that build some time ago and the guy was going for a hidden look, the turbos location was actually a pretty cool idea..
Old Nov 18, 2009 | 12:14 AM
  #65
boogeyman's Avatar
( looks like it was made from compressed dog **** ) best quote EVER
Old Nov 18, 2009 | 11:49 AM
  #66
BlwnLs1GTO's Avatar
Unless there are secret chambers welded inside that muffler that completely block off air flow the each side, that turbo systme is absolutely hilarious!
First off, the turbine inlet AND outlet are mounted in the same air path. Wont work.
Secondly, the wastegate is routed Backwards lol. Wont work.
It's not so much the Fabrication quality, but the flawed design that makes it funny.
EDIT: LOL, I just saw the other picture that shows them mounted under the back seats! When looking at the picture of them on the bench, I thought the Inlet/Outlet was coming from Right to Left. But it's the other way. So that now makes the wastegate correct however, the turbo is going to spin "Backwards" because the Downpipe is now the Up pipe LOL.
Old Nov 18, 2009 | 05:44 PM
  #67
livefast1's Avatar
the mufflers were completely split open and the up pipe was welded inside in the correct configuration, the muffler chamber was left open for the downpipe and the gate to dump into which is actually on the technical side of things a good idea because it would keep more temperature on the up pipe increasing the thermal efficiency of the system. heat expansion drastically increases spool time. try and look on theturboforums.com for the build, the guy knows his ****.
Old Nov 30, 2009 | 01:41 AM
  #68
E-Works's Avatar
r u kidding me?
Old Nov 30, 2009 | 11:43 AM
  #69
rjensen's Avatar
maybe i can hire him to do my turbo setup. im sure he works cheap. but does a honda deserve better though?
Old Nov 30, 2009 | 03:56 PM
  #70
z_speedfreak's Avatar
honduh
Old Dec 1, 2009 | 04:53 PM
  #71
livefast1's Avatar
lot of the pics don't work anymore but i found it
http://www.theturboforums.com/smf/in...topic=114450.0
Old Dec 6, 2009 | 09:49 AM
  #72
livefast1's Avatar
what happened guys, thought his work looked like ****?
Old Dec 20, 2009 | 02:33 PM
  #73
smb72's Avatar
Boy I should take some pictures of some of the **** that some of our guys weld at the shop. We use some high powered Miller welders (440v) and guys can't weld 1/4" steel together without it looking like bubble gum.
Old Dec 26, 2009 | 11:46 PM
  #74
PHOEN1XV8's Avatar
It's no real suprise he had result like that with a chocolate/cast falnge and gasless welder. If you look in the pic of the welded face of the flange, the welds havent even penetrated, just "burned"!!
Old Dec 26, 2009 | 11:50 PM
  #75
1BAD_LS1's Avatar
Restricted User
lmao this thread again..... still makes me laugh, poor guy had no idea what he was doing! But you have to give the kid credit for trying!
Old Dec 26, 2009 | 11:58 PM
  #76
PHOEN1XV8's Avatar
true that. You don't get anywhere without jumping in and giving it a go yourself!
Besides, we wouldnt learn anything if we got it all right all the time
Old Dec 29, 2009 | 10:14 AM
  #77
colt_impala's Avatar
b4 i even clicked the link i saw homemade turbo in the address and was lmao. its like saying a homemade bullet proof vest; nothing good is gonna come from it.haha
