Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
LS Engine puller plate
Old Oct 11, 2009 | 02:32 PM
the_merv's Avatar
Veteran: Air Force
Default LS Engine puller plate
Has anyone seen a plate that you can bolts to where the Valley Cover goes and use it to pull/lift the engine?
I was just wondering.. I'm about to put my engine back in soon and it would help..
Old Oct 11, 2009 | 04:34 PM
highwaystar's Avatar
Yep, Car Shop and a few other sponsers have them
Old Oct 12, 2009 | 10:56 PM
RARON455's Avatar
QTP makes one to.
Old Oct 13, 2009 | 07:44 AM
the_merv's Avatar
Veteran: Air Force
I actually made one earlier today out of some steel I had laying around. I just need some Grade 8 Bolts and I'm good.
The holes aren't drilled yet, but you get the idea..
Old Oct 14, 2009 | 03:52 PM
01ssreda4's Avatar
weld looks a little cold No, seriously, your weld looks a little cold You wouldnt need that plate if you took the motor out from the bottom
Old Oct 14, 2009 | 11:48 PM
daniel6718's Avatar
bottom ftw...dont have to pull tranny or wire harness or headers or accessories
Old Oct 15, 2009 | 01:04 AM
the_merv's Avatar
Veteran: Air Force
K..even if you pulled it from the bottom this little thing will help get it off the K-member with the Cherry Picker..think outside the box fellas..
A friend of mine welded it..it works.
Old Oct 15, 2009 | 02:18 PM
NemeSS's Avatar
if u gonna pull out the bottom, might as well swap in a tubular kmember while your there.
i have always pulled it out the top with hood in place and with trans attached.
merv, i made one like the one u made, but i had the plates made on a cnc waterjet. with a dust shield also, but i dont think there is a market for them.
qtp and other alredy make similar designs
Old Oct 15, 2009 | 03:33 PM
99Bluz28's Avatar
The QTP-10100 is about $53, 1/4" stainless steel.
Old Oct 16, 2009 | 12:56 PM
Phoenix 5.7's Avatar
not the best, but i cut the knock sensor tubes off of a spar valley plate and used that for my last engine swap
Old Oct 16, 2009 | 01:32 PM
the_merv's Avatar
Veteran: Air Force
^^I'm suprised that Cast Aluminum didn't break.
Old Oct 20, 2009 | 07:59 PM
01ssreda4's Avatar
Me too, cast aluminum is weak ****
Old Oct 20, 2009 | 10:11 PM
hookemdevils22's Avatar
like this? 1/4" plate steel. The base is 18.5" x 6", and the vertical plate is 12" x 2.5" with three 1.5" holes. I used the valley cover to mark the bolt holes and drilled them slightly oversized. Note that you have to remove the cam sensor unless you grind it down in the back. $14 for the steel plus weld time, or free if you have some scrap metal chillin' at the shop.
Old Oct 22, 2009 | 03:41 PM
Big_Bird_WS6's Avatar
i got two laying around. 55 shipped. made out a stainless.
Old Oct 22, 2009 | 03:44 PM
for pulling them out the top. i made one with a leveler bar on it. all out of a water jet. and 1/4" stainless. works great.
Old Oct 22, 2009 | 04:13 PM
tittan1500's Avatar
I used the TPIS happy hooker. It worked good and the motor slid right into my trans am.
it has a bend it the lifting hook that helps get past the cowil on the 4th gen cars.
http://www.tpis.com/index.php?module...y=Happy+Hooker
Old Oct 22, 2009 | 11:30 PM
serpentnoir's Avatar
I worked once. doesn't mean it won't break the next time.
You couldn't pay me enough to stand under it. Those welds are horrible. Find someone else to do your welding...
Old Oct 23, 2009 | 06:00 PM
rtpassini's Avatar
is that the only way to take out the engine with a cherry picker?
seems like a lot of work to get that bolted on (but i have never done it so what do i know. haha)
Old Nov 14, 2009 | 03:11 PM
73 nova guy's Avatar
here are the two i built..
one out of 1/4 aluminum
Old Nov 14, 2009 | 05:13 PM
rao's Avatar
rao
Not pretty, but it works.
