Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
any info will help
Old Nov 4, 2009 | 07:22 AM
InTheHawk23's Avatar
Default any info will help
i have 2001 camaro ss and i am removing the motor next week to do a build up and i want to make a engine cradle to set it on since i have all this metal laying around. I was wondering if anyone could tell me the measurement for it or if you have any blueprints like how wide does it have to be and how long it has to be and where the mounts hook up like i said any info will help thanks
something like this would be great
Old Nov 4, 2009 | 01:05 PM
01ssreda4's Avatar
Set it on an old tire
Old Nov 4, 2009 | 02:29 PM
that would be a great idea but i will be taking the pan off so no go for the tire lol
Old Nov 4, 2009 | 02:51 PM
rice4eatingnotdrivin's Avatar
just an idea if u know anyone with a bare block make ur motor mounts with the arms coming off it bolt it to the block then measure ur distance and build the box to that
Old Nov 4, 2009 | 03:04 PM
thats what im looking to do. if this doesn't work
do you know if there is any difference on a old chevy 350 bolt pattern and mount location cause if there not i have another block but it from the 80's camaro out of my 88 camaro
Old Nov 4, 2009 | 03:47 PM
ya im pretty sure there is a difference
Old Nov 4, 2009 | 04:08 PM
Camaroholic's Avatar
Simple...
Make a set of plates... pick your design:
https://ls1tech.com/forums/2845944-post4.html
Bolt the plates to the block. Bolt some flat plates to the back where the bellhousing goes.
Now tack weld some of your tubing to the plates. Unbolt the tacked assembly, weld it up. Done.
Or just go buy a $40 engine stand and $3 worth of long M10x1.5 bolts and get on with business.
Old Nov 5, 2009 | 07:19 PM
01ssreda4's Avatar
If you just need to set the block down, you can with the pan off. It has studs sticking out of the main caps.
